lakeside53
01-05-2008, 01:16 AM
Ok.. Long post. Bear with me… I have read every post about bearings (those that came up in searches!) on this site, Yahoo groups, PM etc, and still have questions on bearing replacement in the J head, and the lubrication system.
I’ve taken apart my step pulley J-head (1967) to the bare iron, cleaned and inspected everything and now I’m ready to reassemble it, replacing several parts with used, and some new bearings. It had numerous small issues, but has basically been neglected, robbed for parts and partially disassembled by “somebody without a clue”.
I need to replace my pulley, lower bull gear housing, and top spindle bearings. My lower spindle bearings, after cleaning, seem “o.k”. I looked up the prices with the usual suspects, and came up with big swings in prices.
For the 5 bearings, my total from ICIA – $340.20; H&W - $64.75; Alternate - $437.40…. wow… not so much the prices, but the differences. So I dug a little deeper.
Pulley bearings:
My 1968 manual says “one pair 207”.
Later parts lists say 207KDD DB732
Mine are MRC207SFF DB. The “DB” is engraved by hand. I’m 100% sure they were assembled (no idea by who) in reverse – face to face, instead of back to back.
ICIA - $18.90 each
H&W - $11.96 each
Alternate - $24.30 each
Question: None of these prices seem to reflect “DB”. Do these bearings need to be “DB”?
Bull gear bearings:
1968 - “I pair 208”
Later - M208K DB J732
Mine - Fafnir M208K C2 - no sign of “DB” or side markings
Question – what is the significance of the single “M” in the Fafnir bearing number? I know “MM” denotes precision.
ICIA – $56.70 each
H&W - $16.16 each
Alternate - $72.90 each
I’d like to think ICIA and Alternate are supplying “DB”, but…
Top spindle bearing:
1968 – FAFNIR M206K spec E6578
Later - M206K 123J30
Mine – 6206 C2.
ICIA – $94.50
H&W – $8.51
Alternate - $121.50
Again, it “seems” (from the price) ICIA and Alternate are supplying higher precision bearings. However, I read both on this forum and other places that a precision bearing is not required in this location…
I’m guessing my bearings are the originals. They suffered from both too little oil at times and the “dumb” dirty lubrication system. Any junk that gets into the pulley area can get into the reverse gear housing. Once there, it’s a short trip THROUGH the lower bull gear bearings to the quill and spindle “filter” – the felt pad. How good a filter is this pad? Then give it a few years or decades. In my case the felt had at some point partially dried out and distorted. Plenty of pulverized chip material was evident. Some chip and dirt material made it to the top spindle bearing, and some likely down to the main spindle bearings. The killer for the top spindle bearing was water in the felt that made a spot of rust.
I see that H&W supplies a SHIELDED (not sealed) top spindle bearing. You’re then supposed to grease the lower spindle bearings. IMO.. over time the oil that required for the bull gear bearings is going to pool up on the bearing shield and wash out the grease. The lack of oil flowing though the spindle bearings is going to allow dirt to get back though the nose drain holes and labyrinth seal grooves. Even if SEALED ABEC7 spindle bearing are deployed, oil is going to fill up the quill above the bearings. Am I missing something?
So… WHAT if I put two sealed bearings in the bull gear housings and fill it with grease etc like the Series 1? At least the junk from above won’t be washed into my quill/spindle bearings. Then either, continue to use the existing loss system with open sprindle bearings, or, seal all spindle bearings and redirect the wick to just oil the quill area.
Any experiences with the above suppliers bearings?
Comments?
p.s. Apologies to members of the Yahoo bridgeport group - I posted there also but the post is hung up waiting for approval.
Pulley bearings:
ICIA - $18.90 each
H&W - $11.96 each
Bull gear bearings:
1968 - “I pair 208”
ICIA – $56.70 each
H&W - $16.16 each
Mine – 6206 C2.
ICIA – $94.50
H&W – $8.51
Alternate - $121.50
Comments?
