View Full Version : 954 Bronze
01-27-2008, 01:02 PM
Could that be used for bearing material instead of 932?
Extremely low load/speed, etc.
01-27-2008, 01:07 PM
Alloy 954, aluminium bronze has high
strength with good impact, wear and
corrosion resistance, high resistance to
oxidation and good strength at
elevated temperatures. Anti-seizure
properties, however, are poor.
Typical Applications:
High strength bearings, bushings, bolts,
gears, gear wheels, guides, pump rods,
propellers, pickling hooks, valve seats,
worm wheels and non-sparking tools etc.
01-27-2008, 01:46 PM
Pickling hooks as well!?
And cheaper than 932! Oh, I'm in shape now.
;) Thanks mate.
01-27-2008, 01:59 PM
Aluminum bronze is very hard. Make sure it's not harder than the parent (sliding) metal.
Spin Doctor
01-27-2008, 07:24 PM
660 bronze
01-27-2008, 09:52 PM
Thanks for the link!
01-28-2008, 12:52 AM
C923 is a step up from C932 (660) and is used for high-load bearings. It's about the same but has a little less lead. The 923 is also called Navy G-brass. The problem I'm having is finding a place that sells it in shapes other than ingot. :eek:
