View Full Version : Polishing Corian
Tim Clarke
02-09-2008, 07:24 PM
I've been busy overhauling my ancient Sears tablesaw. I scored a nice piece of Corian to put on the rip fence. As promised, it cuts nice with the carbide blade, and rounded with the router. I sanded a little with 220 grit, smoothed right up. It would really be gorgeous with a mirror polish. So what would you use. Have a cotton buffing wheel, but what abrasive to use?
Many thanks, Tim
02-09-2008, 08:06 PM
A member of home model machinist makes engines out of it it..
The best way I have found to polish plastic is wet sand 320.400.600 then follow medium grade auto polish then a good plastic polish. Mothers plastic polish here in the states works well but a good grade from the auto supply store should work. The cheap stuff is a waste of time and money.
02-09-2008, 08:57 PM
We installed Corian in the kitchen a couple of years ago. I found the following info from a company called Micro-Surface to be useful (link at the end):
Solid Surface Finishing Procedures
Tools Required
Random Orbital Sander
Micro-Mesh Aluminum Oxide Discs
(Discs are available in any size, hole pattern and backing)
Finishing Step Guidelines
Deep Scratch Removal:
Matte Finish: 300 AO, 600 AO
Satin Finish: 300 AO, 600 AO, 800 AO, 1500 AO
Gloss Finish: 300 AO, 600 AO, 800 AO, 1500 AO, 2400 AO, 4000 AO
High Gloss Finish: 300 AO, 600 AO, 800 AO, 1500 AO, 2400 AO, 4000 AO, 12000 AO
Note: not everyone's idea of a particular finish is the same. Depending on the color and type of solid surface, fewer or more steps may be required in order to achieve the look you want. It is a good idea to check the finish between grades until you become familiar with using Micro-Mesh.
When used properly Micro-Mesh discs will provide you with the best finish imaginable. No special tools are required and you will be able to achieve a matte to a high gloss finish without the use of water or buffing compounds making them not only perfect for a shop environment, but excellent for on-site repairs. Engineered to effortlessly glide across the material, Micro-Mesh greatly reduces the amount of fatigue that fabricators would normally endure while sanding. With Micro-Mesh there is less heat generation so you won't have to worry about burning the material.
Helpful Hints
1. Light pressure should be used to control sander. The sander should be moved in a random pattern, or in circular motion to "blend" the scratch pattern. We suggest alternating a North/South, East/West pattern, covering the entire surface.
2. The sander should be in contact width the surface before it is turned on. Remove the sander from the surface prior to turning the sander off.
3. Micro-Mesh can be used wet or dry and is reuseable. Simply rinse out the discs and allow to dry.
4. The beginning condition of the solid surface material will determine your starting point. Follow the first step until all of the beginning damage is removed. Make certain to wipe away any sanding debris prior to continuing on with the next step to avoid contamination scratches. Also check the scratch pattern left to make certain that the surface was completely sanded.
5. Each additional step should be used for approximately 1-2 minutes per square foot or until the previous scratch pattern is completely removed. Gloss finishes may require additional time.
Trouble Shooting
Swirl marks in the finish: do not skip steps. Spend approximately the same anount of time on each step. Be sure to completely remove sanding residue before moving on to the next step. Move the sander in a consistent pattern. Apply less pressure - excessive pressure will change the orbit of the sander causing "fish hooks" in the finish.
Finish not glossy enough: for Micro-Mesh grades 300 AO thru 1500 AO use a standard back-up pad. Change to a soft back-up pad for grades 2400 AO thru 12000 AO.
Finish not matte enough: use a firm back-up pad.
Milky/Hazy appearance: repeat the last step using a spritz of water.
Home owner can't maintain finish: Micro-Mesh Soft Touch Pads are available in any grade or combination of grades. Leave with the home owner so they can feather out scuffs and light surface scratches.
If the finish you desire is not obtained, please contact Micro-Surface Finishing Products Inc. at 800-225-3006 or 563-732-3240 for assistance.
Standard disclaimer. Just a satisfied customer.
Edit to correct company name from Micro-Mesh to Micro-Surface. Reasonable prices and good customer service.
Rich Carlstedt
02-09-2008, 10:28 PM
I wet sand Corian with 400 grit, and finish with 1000.
An orbital sander running on a water film is great .
After the 1000, I can see no lines on Black Corian.
Follow this with Turtle Wax.
