View Full Version : small OD copper tubing
Elninio
02-13-2008, 02:55 PM
Is there copper tubing with OD of ~ 4mm? What is the smallest OD copper tubing available and where can i find some? Im planning on building some heat sinks.
rkepler
02-13-2008, 03:13 PM
Refrigeration capillary tubing comes in that and smaller diameters. I've used stuff less than 2.5mm in diameter.
hornluv
02-13-2008, 03:16 PM
Most hardware and hobby stores carry the K&S Engineering display. They generally have copper tubing down to 1/16th od by 32nds. 5/32" is .15625 (3.96875 mm).
Stuart
Edit: the wall thickness on that tubing is .014" BTW
SGW
02-13-2008, 03:59 PM
www.smallparts.com has small-diameter tubing.
small.planes
02-13-2008, 06:21 PM
copper brake pipe from an auto factors? I think 3/16th is the smallest 'normal' size tho
Elninio
02-13-2008, 07:50 PM
i wonder if home depot has some. what would they call it? im sure the guys working there wont have any idea what im talking about if i ask them for small OD copper tubing..
thanks in advance
Rich Carlstedt
02-13-2008, 08:08 PM
Hobby shops
They carry 1/16 copper tube.
You can also get 1/32 SS tube from Walthers Hobby in Milwaukee
Rich
Elninio
02-13-2008, 08:09 PM
im looking at multi-hole EDM tubing, has anyone has any experience with this, how expensive is it? (trying to maximize surface area - can either have lots of small tubes or can have bigger tubes that are sub-divided inside)
jim_geib
02-13-2008, 10:20 PM
Might look at the therm-o-couple used on gas hot water heaters.it would be close to 4mm
jimsehr
02-13-2008, 10:52 PM
EDM supplies has copper tubing starting at .01 x12 inches long and they have it in .001 steps up to .25
800 676-7336
Jim
Elninio
02-14-2008, 11:44 AM
thanks everyone! ill try to get some this comming week
