View Full Version : brockley1
Oldbrock
02-19-2008, 06:30 PM
http://i273.photobucket.com/albums/jj232/brockley1_bucket/lathepics004.jpg Up to now I have only browsed the site and tried to help where I can. I thought at least one of you may have sometime tried to screwcut wood. Not easy with a single point tool. I know there are special dies out there to thread dowel but I wanted to "Do it my way" This is my dremel flex shaft end with a 1/8" ball cutter threading 4 T.P.I. (just in case anyone is interested) Peter
Carld
02-19-2008, 06:39 PM
How are you going to do the internal thread?
Oldbrock
02-19-2008, 07:23 PM
meant to post the internal thread cutter for it. Will do the setup and post tomorrow, have to go to band practice now. Peter
GKman
02-19-2008, 08:35 PM
Thanks for posting. Looks good. Heard that apple wood is good for threading.
TGTool
02-19-2008, 10:59 PM
Nice looking work. Looking at your setup, you could do regular 60 degree threads with a tiny dovetail cutter, one flank of the tool on one flank of the thread, and the other thread flank with the end. May have to try that ...
barts
02-20-2008, 12:54 AM
This is how I made a form for bending sand-filled 1/2" Cu tubing into 4" diameter coils for my steamboat boiler... I used a 1/2" carbine ball in a air die grinder on my 10" Atlas... I turned it over by hand since the lathe didn't go nearly slow enough. I use a piece of 4" square maple as the form.
Oldbrock
02-20-2008, 11:20 AM
http://i273.photobucket.com/albums/jj232/brockley1_bucket/CIMG0547.jpghttp://i273.photobucket.com/albums/jj232/brockley1_bucket/CIMG0550.jpg If these pics come through (I'm still a computer idiot) the cutter I made for the dremel is the mirror of the male thread, and there should be a pic of the nutcracker, not my idea, someone in Saskatoon, Sask.
Oldbrock
02-20-2008, 11:30 AM
http://i273.photobucket.com/albums/jj232/brockley1_bucket/CIMG0547.jpghttp://i273.photobucket.com/albums/jj232/brockley1_bucket/CIMG0550.jpg I know I'm coming across as a computer idiot. I'm trying again. the cutter was made from drill rod and finished nutcracker.
Oldbrock
02-20-2008, 11:31 AM
now I am pissed
Oldbrock
02-20-2008, 11:37 AM
<a href="http://s273.photobucket.com/albums/jj232/brockley1_bucket/?action=view&current=CIMG0550-1.jpg" target="_blank"><img src="http://i273.photobucket.com/albums/jj232/brockley1_bucket/CIMG0550-1.jpg" border="0" alt="Photobucket"></a> Who knows what will work ( if I press ctrl-a the whole damn page wants to transfer)
Your Old Dog
02-20-2008, 11:43 AM
curiosity got the better of me. I have to ask. Not to be confused with a stereo nutcracker, is this a mono nutcracker? And how do you propose to crack the second nut onces the game is up? :D
Your Old Dog
02-20-2008, 11:47 AM
Brockly, once you bring up a particular photo, look to the lower right of the screen and you should see the url for you to copy. Each of the 4 urls will offer the image in different sizes. Click on the url you want and it copies to your clipboard. Then come over to this forum, position your curser where you want the image to appear and then right click and then hit paste and you're done. good luck
Spin Doctor
02-20-2008, 12:04 PM
In one of the woodturning books I have read there is a picture/s of a head that sets on the ways of the lathe on a cross slide that uses inserts of different pitches to get the TPI you want. It holds the work being threaded. The cutting tool (think small mill cutter) goes in a collet or drill chuck (the horror) in the lathe's spindle. Primarily used for making screw on lids for turned boxes. IIRC the book is by Richard Raffin
http://search.barnesandnoble.com/booksearch/isbnInquiry.asp?z=y&EAN=9781561585090&itm=5
But then if I was shopping for a wood lathe and money was not the main concern I would really think about one from these guys. I talked to the owner at a wood show a couple of years ago and we had a nice talk. He has a backround as a tool maker/machinist and I expressed my feelings that it would be really nice if there was a wood lathe that had a big enough spindle to take a 5C collet in the spindle. He agreed but said it was a matter of money and a certain amount of inertia on the part of the wood turning community
http://www.turnrobust.com/
Oldbrock
02-20-2008, 12:10 PM
http://i273.photobucket.com/albums/jj232/brockley1_bucket/CIMG0547-1.jpg Thanks old dog, see if this works, Peter
pcarpenter
02-20-2008, 12:53 PM
The link is fine. If you want to past the image, you need the one with the "bb code" in it. It will start with <IMG as I recall, and you must include the full line including the IMG tag portion.
Paul
Oldbrock
02-20-2008, 10:14 PM
Ya, Ya, you'd be in too much agony to do the other:D
tattoomike68
02-20-2008, 10:24 PM
that looks like a nice weed pipe.. :D
