View Full Version : HS tool Grinder
Jim Hubbell
02-19-2008, 11:43 PM
I need to replace the wheels but can't seem to find where to buy them. Any help will be appreciated.
Jim
edit: Should be HF tool grinder.
Carld
02-20-2008, 12:23 AM
MSC, Enco, JTS, CDCO, Travers and a few others I can't think of right now.
lazlo
02-20-2008, 09:08 AM
Jim, the wheels for the Harbor Freight carbide grinder are a little hard to find -- they're Type 35 Plate Mounted Wheels.
J&L Industrial sells an unbranded A46 plate mounted wheel for ~$45 -- it's actually a Norton OEM wheel. Wait for the 25% off sale every three weeks.
KBCTools also sells a Chicom A46 plate mounted wheel for ~ $40.
Enco doesn't carry them, and MSC only carries the Norton-branded plate mounted wheels, which are $90 each.
jimmstruk
02-20-2008, 09:49 AM
I bought my wheels from JTS. They carry several brands and were much more reasonably priced, also have choices of grit. JIM
BobWarfield
02-20-2008, 11:16 AM
One of the older threads recommended these two, which I bought:
Diamond 220 grit from Enco
Aluminum Oxide 46 Grit from J&L
