View Full Version : Delta Bandsaw Mods
ed_h
02-20-2008, 12:21 AM
I have a Delta wood-cutting bandsaw that I wanted to modify to cut both metal and wood. At the same time, I reduced the base size to take up less floor space:
http://bullfire.net/WP_Delta_Bandsaw.html
Corm
02-20-2008, 08:55 AM
Nicely done!
Bill Pace
02-20-2008, 09:06 AM
Cant quite tell in pix, but is the second motor (the original?) mounted so that you can do a belt change and regain the original speed/sfpm?
I always wondered why they stuck the motor back there anyway, what with that room underneath....
So, How did the gear motors speed work out, did it hit on a good sfpm for doing metal?
Garauld
02-20-2008, 09:16 AM
Nice job. I did a similar mod to mine - I installed a 1/4 hp gearmotor onto the lower shelf and used a chain drive due to the higher torque. I removed the driven sheave and replaced it with a sprocket. I kept the stock motor intact, but added a two way switch so I can control either motor separately. If I need to cut wood, I remove the driven sprocket and reinstall the driven pulley and belt.
ed_h
02-20-2008, 09:56 AM
Yes, the motors are positioned so I can swing the belt to either one. The tensioner moves to the other side.
The slow motor gives around 170 sfpm. I may instal a VFD, switchable to both motors, to get more control.
rklopp
02-20-2008, 02:59 PM
Here is my take on the same. It has two speed ranges plus a VFD.
http://www.metalworking.com/Dropbox/Rockwell_Bandsaw_01.jpg
http://www.metalworking.com/Dropbox/Rockwell_Bandsaw_02.jpg
http://www.metalworking.com/Dropbox/Rockwell_Bandsaw_03.jpg http://www.metalworking.com/Dropbox/Rockwell_Bandsaw_04.jpg
