View Full Version : picked up that mill today
kjbllc
02-23-2008, 06:53 PM
here are some picks. the lever to engage the auto feed is broken. On the second photo there is a hole that seems like it should have something either coming out of it or covering it, above the chrome hand wheel , for changing the feed speed gears.. Its a little stiff but things work, did some rough milling on it.
http://i254.photobucket.com/albums/hh92/kjbllc/mill1.jpg
http://i254.photobucket.com/albums/hh92/kjbllc/mill2.jpg
aboard_epsilon
02-23-2008, 07:09 PM
that hole is for when you push the over-arm back...when mouting a shorter arbour ...or just milling with a stub arbour .... ...it comes out the back
all the best.mark
kjbllc
02-23-2008, 07:13 PM
is that how you use the big mills that attach to the screw at the (right end on the machine facing the picture)? I got some big mills with it that look like the screw on the end but it looked like they would be stuck way out there and not enough support.
aboard_epsilon
02-23-2008, 07:52 PM
I wouldn't put anything more than 6 inches diameter on that mill
the big mills larger than 6 inches are for bigger machines.
the screw thread ones may be hobs ...for cutting gears
you will have to show us some pics of them
nah forget the last sentence ...im misunder standing you ...
to put cutters in the mill without the arbour you may need a draw bar.
a draw bar is a long bar with a nut at one end and a thread at the other ...
it passes down the spindle of the machine ...screws into the collet chucks...that are inserted into the taper you have there when the long arbor is removed.
...eg ... collet chucks are 30 international or morse taper ones.
and look like this ..30 international are shown in picture.
these are for holding endmills ..
the one in the middle is a morse adaptor ..
you can also get them with a Norton dead lock thingy ...you can hold large cutters with these ...over one inch in diameter .
http://img.photobucket.com/albums/v190/aboard_epsilon/bridgeport/1BE.jpg
here you can see a deadlock chuck with cutter mounted ...think the guys mixed up ...calling it clarkson ...which is yet another system
http://cgi.ebay.co.uk/Clarkson-Deadlock-Chuck-With-47mm-Cutter_W0QQitemZ350000744975QQihZ022QQcategoryZ252 92QQrdZ1QQssPageNameZWD1VQQ_trksidZp1638.m118.l124 7QQcmdZViewItem
all the best.markj
tiptop
02-23-2008, 09:44 PM
The drawbar is in your mill now. It is at the opposite end of the arbor with the square head on it. It is being used to hold your arbor in. The threads on the drawbar are 3/8-16 and the taper is morse #2. They make end mill holders and shell mill holders with that taper. I personally would not run a cutter over the diameter of 4" on an atlas MFB. They are good mills for what they were designed for, but light duty is the key. You can do a lot of milling, it just takes longer. Have fun, Jay:)
Oldbrock
02-23-2008, 10:05 PM
Hey, good score Kevin, it would be great if you can find either a vertical or universal head for it. My little limey mill is a horizontal, but I also have a vertical head for it and use it most of the time. Keep your eyes peeled, maybe one will jump out of the bushes. Have fun staying out of the kitchen, Peter
uute
02-24-2008, 03:17 AM
I'm drowning in drool here!! :D :D
Guess you won't have any trouble making that T nut for the QC toolpost now!!!
:D :D
CT2
kjbllc
02-24-2008, 08:32 AM
thanks, I will get a pic of all the tooling that came with it, I will need some help on IDing the tools. I am going out right now, the sun should have warmed the shop up a bit!
kjbllc
02-24-2008, 06:53 PM
well here is the picks of the tools. I guess a lot of them are not for this mill.
http://i254.photobucket.com/albums/hh92/kjbllc/tooling.jpg
aboard_epsilon
02-24-2008, 07:18 PM
see them long things with multple cutters on them
they are broaches ...used for making keyways etc ...
clean them up ...and they will fetch a fortune on ebay ...may even pay for your machine ..
EDIT
just looked at ebay.....i was thinking jlindustrial prices ...and second hand would be expensive ................
they are cheap "new " on ebay ...
all the best.markj
aboard_epsilon
02-24-2008, 07:35 PM
look out for these on american ebay
they will get you started
http://cgi.ebay.co.uk/2MT-MILLING-ARBOUR-MILLING-MACHINE-ECT_W0QQitemZ330213999640QQihZ014QQcategoryZ12584Q QssPageNameZWDVWQQrdZ1QQcmdZViewItem
http://cgi.ebay.co.uk/ER25-MT2-3-8-COLLET-CHUCK-CNC-MILLING-LATHE-NEW-A68_W0QQitemZ110224744866QQihZ001QQcategoryZ12584Q QssPageNameZWDVWQQrdZ1QQcmdZViewItem
also you need er25 collets to go with the chuck
kjbllc
02-24-2008, 07:37 PM
EDIT
all the best.markj
thanks for the heads up, they are old probably from the 60's or so, definitely not imports. Is there a special machine that uses them?
aboard_epsilon
02-24-2008, 07:40 PM
they are for a machine with a turrete head...like a bridgeport and a lever operated quill.
all the best.markj
kjbllc
02-24-2008, 08:18 PM
thanks for the help epsilon, I guess you could use them minimally in a drill press?
lane
02-24-2008, 08:34 PM
They are old probably from the 60's or so, The 60`s aren't old that was just yesterday. You want old try the 30`s.
JCHannum
02-24-2008, 09:06 PM
Broaches are pressed through the workpiece with an arbor press or hydraulic press to cut a keyway inside a pulley for instance. You need the bushings and shims to fit the various sized bores.
The end mills can be used with MT#2 collets or draw in MT#2 end mill holders. The maximum shank a MT#2 will accept is 1/2".
The mill already has the proper MT#2 arbor, and additional arbors are not needed. 7/8" & 1" arbors were available from Atlas, the diameter of the bore of the cutters will determine if they will fit. Atlas used a driver for the arbor that is fitted to the spindle nose. If other arbors or MT#2 tooling is used, a suitable driver should be fabricated.
Lane, what do you mean the 30's is old. 60's is kid stuff, 30's is seasoned.
kjbllc
02-25-2008, 08:30 AM
thanks that helps a lot, your right the 60's isn't that old, I am teaching a bunch of 20 somethings and they have gotten me thinking that the 80's is old.
