I've been using the injection molder a bit and I've figured out what I want to change now to make it really usable.
One thing is to remake the heater block out of round stock so I can use standard band heaters and a nozzle heater. The block will be 3" dia and the nozzle will be 1" dia. The block will have a .5" bore for the piston.
Any suggestions for the metal for the heater block? It will get heated and cooled many times over use life to 500+ deg F.
I figure I want to use hot rolled although because I'm putting a small bore through a big block I don't figure I'd see any distortion with cold rolled.
Carbon or alloy steel? Would 12L14 be fine or should I use something more like 1141.
Thanks, any suggestions would be nice.
I'm also planning to add hydraulics for piston ram and mold clamp.
PS. Or maybe I should be asking about metals to stay well away from. I figured stainless was one for this.
[This message has been edited by brunneng (edited 06-10-2003).]
