View Full Version : Rubber Bar Material?
06-10-2003, 11:36 AM
I have been Searching for Some Two Inch Diameter Black Rubber that is One Inch Thick. I need Six Pieces and it needs a three Eighths Inch Hole through the Centre. Any Ideas where to get some? Audrey
06-10-2003, 12:04 PM
Are you talking about a hockey puck with a 3/8 hole drilled in it?
06-10-2003, 12:30 PM
Boat trailer rollers
06-10-2003, 01:24 PM
Automotive/truck type body mounts, also commonly available in polyurethane. Can also get machine mounts through Graingers or MSC (I think).
06-10-2003, 03:35 PM
I picked up some really good rubber blocks at a rail yard once. That will be my first choice when I need some substantial rubber pieces again.
06-10-2003, 06:27 PM
You can get 75 Shore (A) (HARD) Neoprene tubing 2"x3/8"x 36" #57802834 ($65.37) from JDR Industrial www.industrialequipmentsupply.net (http://www.industrialequipmentsupply.net) or 888-874-4421
Cut it with a mean hook (extra sharp cut off tool or hacksaw/bandsaw). A Japanese Ikeada tooth hand saw will also cut it but it takes some work.
This is actually die pad material, but it will work. The other source you could try is a caster supply house - I would get aluminum Polyurethane faced wheels.
[This message has been edited by Thrud (edited 06-10-2003).]
06-10-2003, 09:28 PM
Rubber shock absorber washers,wow!twice in the same day http://bbs.homeshopmachinist.net//biggrin.gif
