Anybody have a cad program that could whip me out an answer ?
Material .063" thick. 82* countersink, upper dia .307" lower dia. .197"
If you dropped a .3125" ball into the countersink, how much of the ball would be protruding above the surface ?
Material starts out at 3/16" thick, but gets milled down to the .063" dim. from the opp side, down the length of the part (15")
The lower Dia. of the countersink is +.000 -.005 .If the lower dia. tolerance is blown, the part is scrap. At .063" the material is too bendy to clamp in the vise and too springy to drill reliably, so the countersinks have to go in first, then mill, and still keep my fingers crossed that I haven't over-tightend the vise and cause the part to deflect while milling, scrapping the part.
With the ball height I can at least reliably set the CS depth, then worry about bringing in the thickness.
Any help appreciated
kerry
kerry
