hwingo
03-18-2008, 10:29 PM
Hey Guys,
My brain isn't working and I need some help on how to cut a radius. I'm no good at drawing pictures so the two attached images is the best I can do but maybe they will help to fill in the gaps as I try to explain what I want to do.
I will be working with square stock that's 1" thick. I want to cut a "flat" at the end of stock. This flat is to be cut half way through the stock (1/2" deep cut) using a 1" dia cutter to full diameter. This flat is to mate with a second flat that looks exactly the same and bolted together via a center hold. Once the flat is cut, I want to radius the corners so they match the radius of the 1" dia cut. Obviously a deep radius-ed lip will remain. I have an 8" rotary table for the mill. How do I go about setting up the rotary table when cutting the radius so that when I rotate the table, it will cut a radius that will match the 1" circle? When finished, I want it to look like the top view (second image)?
Harold
http://i234.photobucket.com/albums/ee38/hwingo_2007/Untitled2.jpg
http://i234.photobucket.com/albums/ee38/hwingo_2007/Untitled3.jpg
Harold
