View Full Version : anyone have info on Pennant jeweler's lathes?
andy_b
04-15-2008, 07:27 PM
i'm trying to find info on an old Pennant jeweler/watchmaker lathe. i'm guessing they will take many of the common accessories for the average 8mm lathes, but so far haven't found any info.
any info is appreciated.
andy b.
04-15-2008, 08:55 PM
Don't have info, but DO have a question.........
You mentioned "average 8mm lathes"..... What measurement is that "8 mm"?
I have a Boley that takes WW collets, would that be an "8mm lathe", for example?
andy_b
04-15-2008, 11:34 PM
JT,
i'm no jeweler lathe expert, but from what i understand, 8mm and WW seem to be used together quite often. i have no idea if that means interchangeable or not.
i did a search over on the PM site, and all i turned up was a guy asking questions about one a few years ago (no replies) and a guy selling one a few years ago (again, no real info). of course, i always seem to find these orphan tools from companies that no longer exist. sort of like the old Hisey horizontal mill i have.
andy b.
hoof
04-16-2008, 07:57 AM
I believe the 8mm is the collet diameter, The WW is for Webster Whitcomb, I only assume the first folks with the basic design that then became a standard. There is a realy nice book (Although very expensive) at this link. The authors name is Theodore Crum. I had the volume and it was destroyed in a flood in my cellar. http://www.horology.com/hs-tools.html I hope you find the link useful.:D
Hoof
andy_b
04-16-2008, 09:16 PM
Hoof,
thanks for the info and link. your explanation of WW sounds reasonable. i guess if most of these small lathes are of the WW-pattern, and 8mm collets seem to be the most common, then i'd guess i have a pretty good shot of matching WW-pattern and 8mm size items up with an old Pennant lathe.
andy b.
