View Full Version : Single Flute Countersink Sharpening
Bgmnn1
04-25-2008, 05:23 AM
Any one sharpening their own single flute c'sinks?
Is any one using the single flute sharpening fixtures sold by MSC, etc?
Thanks in advance,
bgmnn
IOWOLF
04-25-2008, 06:02 AM
Any one sharpening their own single flute c'sinks? Yes.
Is any one using the single flute sharpening fixtures sold by MSC, No etc?
Thanks in advance,
bgmnn
I made my own, with help from someone on this board, search the archives from about 9 months ago.
Bgmnn1
04-25-2008, 10:55 PM
Was this Old Tiffy?
All his imput to that thread is deleted.
Could you share your fixture information?
oldtiffie
04-25-2008, 11:04 PM
Thanks in advance,
bgmnn
Hi bgmnn.
First of all, I think I'd rather not comment on that previous thread.
But having said that, can you provide pics or links for your particular single flute counter-sink cutter and the sharpening equipment at MCS etc. that you refer to?
That will focus the responses to your specific counter-sink and tools etc.
Anything else or less may well result in "hit and miss" response/s.
IOWOLF
04-26-2008, 07:50 AM
Well It is kind of trial and error, IIRC Mine is offset by .030 and a 1/2" hole drilled and reamed in it, then it is finding the good High spot to align the cutting edge up to , then it is just a matter of spinning it up against a grinder.
They do cut well when you get the geometry correct.
JCHannum
04-26-2008, 08:36 AM
Basically, they are just an offset sleeve as Jay describes that backs the cutter off as it is turned. You can probably measure the offset directly from the cutter by indicating it in the lathe.
The MA Ford cam is oversized and is furnished with sleeves for the various shank sizes. It grinds the OD, but not the cutting edge as I recall.
Bgmnn1
04-30-2008, 03:06 PM
oldtiffe,
Here are the images at the MSC web site.
MSC # 45117520
MSC # 63774996
MSC # 01053651
Thanks,
bgmnn
Bgmnn1
05-01-2008, 11:33 AM
Just bumping it up.
