View Full Version : Enco mill-drill Model 91002
gld
04-27-2008, 02:40 PM
I've sold my old enco mill....the fellow who bought it would like to have the belt pulley chart.....
Can't find mine.....would anyone happen to have one that could send me a copy ??????
Thanks
wirewrkr
04-28-2008, 11:48 PM
are you talking about the belt position and related speed chart on the front of the machine?
I've got a 91000, it might be the same, I could shoot a pic and email it.
Robert
gld
04-29-2008, 09:53 AM
Robert
Yes-- that's it.
Thanks
lazlo
04-29-2008, 11:31 AM
This is from the PDF manual for my Enco 105-1117 Mill/Drill, the resolution sucks, but that's what the original looks like:
http://i164.photobucket.com/albums/u15/rtgeorge_album/milldrill.gif
wirewrkr
04-29-2008, 02:20 PM
Thats totally different from the 91000 model, I just shot a pick and will email it to you.
Robert
wirewrkr
04-29-2008, 02:27 PM
Just sent it. Hopefully it's clear enough, if not let me know.
Robert
gld
04-29-2008, 08:44 PM
Robert
It's very clear, just not the wright one...... my old mill only has a 2 step on the motor.
Thanks
wirewrkr
04-30-2008, 12:39 PM
did you try contacting Enco?
When I got mine, I called them and the woman I spoke to dug up a parts book and sent it no charge, really helpful.
Robert
gld
04-30-2008, 08:06 PM
Robert
Guess I'll get it a try.....This thing is goin on 30 years old.....I'll be surprised...
wirewrkr
04-30-2008, 11:56 PM
worth a shot, what the hell.
Robert
bruto
06-01-2008, 07:23 PM
Bump!
Just in case this was never resolved, I recently got an Enco 91002, and here is the belt chart from the front of it:
http://img68.imageshack.us/img68/8309/encobeltcharteq3.jpg (http://imageshack.us)
I have also scanned the instruction manual, and the PDF is available here:
http://www.box.net/shared/e21b39lgcs
gld
06-02-2008, 10:54 AM
Bump!
bruto
Exactly what I was looking for......Thank you very much
SU 29
01-10-2012, 07:27 AM
Looking at the speed chart above, what does the 4P and 8P represent? Would the RPM change or be different between 110v vs 220v?
I believe they relate to the number of pulley's but I don't want to assume that. I have not run across an eight pulley mill-drill yet.
Thanks for the clarification
Jeff
EVguru
01-10-2012, 08:02 AM
Jeff
It's referring to the number of poles in the motor, which is a two speed jobbie.
flylo
01-10-2012, 08:53 AM
I just sold one from 1982 & it had the 4 step pulley. If all else fails he can get a small digital optic tach that uses the reflective tape for $10 shipped on ebay ,check the RPMs & make his own chart. It's very handy around the shop.
bruto
01-10-2012, 09:33 AM
It's referring to the number of poles in the motor, which is a two speed jobbie.Yes, it's poles in the motor. On mine, a two pole, the voltage remained the same when I rewired from 120 to 240 volt.
edit to add: I meant RPM, not voltage above.
SU 29
01-12-2012, 05:33 AM
Best I can tell, my mill is also the 91002, early 80's model. It is a single speed, 110/220 reversable motor.
Should I use the 4 pole RPM's based on the info above?
I will check into a rpm meter, I have looked at those but way expensive but for just a few bucks, hey why not.
Thanks guys.
Jeff
