Dawai
04-29-2008, 02:38 PM
I bought two gecko drives to go onto my shaper for a gear cutter.
OKAY.. I got one more drive to buy now and motor.
I got bored slapped this together, done tested and calibrated it. It has some bad end play as most the chinese cross slide tables, but seems to work fine.
http://img.photobucket.com/albums/v85/ibewgypsie/XYSlideDrive.jpg
http://img.photobucket.com/albums/v85/ibewgypsie/xySlide.jpg
What's it good for? well I got a arm cut out for the plasma torch, it has a 4x6" cross slide.. meaning it can be moved around a sheet of metal to cut out parts. TORCH holder, then well the indexer I got a pulley on needs a drive and motor.. then, a end mill sharpener, spins as rotates as feeds.. need a cup wheel to go onto my grinder.
Side projects off this portable slide..
1: end mill sharpener
2: small flame-plasma cutter
3: gear cutter for shaper
4: mini pcb drill (using the drill spindle I salvaged off another project)
If I get bored with it, I can always pull the parts for the next project.
Here's my first cnc project, ran with transistors and logic inverter chips. BRUTE, resistor current limit. SLOW as christmas and not as much fun. A good learning project thou.
http://img.photobucket.com/albums/v85/ibewgypsie/MILL3.jpg
