View Full Version : Another Noobee question
davidwdyer
05-01-2008, 07:34 PM
Has anyone used a carbide tipped saw blade, the 3 1/2" or 4" variety, for slotting steel, aluminum, etc. on a mill?
Is there a difference between the carbide on other tools and the material on a saw blade?
Could such blades be used, for example, on a horizontal attachment for a Bridgeport?
Obviously, these blades would need to be run at slow speeds, but would it work?
Any thoughts or experiences?
Deja Vu
05-01-2008, 07:39 PM
This subject has been covered several times here, but I want to learn more about this too.
I think I've seen pictures of a small 3 or 4 inch 40 tooth? carbide blade sloting some parts here. I think the speed was relatively high though I may be wrong. There was something about the making of an arbor for it too.
Others will post here with directions to the existing archives ...I hope! :)
P.S. I also saw a picture of a blade that jammed and got crumpled into pieces.
lane
05-01-2008, 07:49 PM
Try it . What do you have to loose . Just a carbide blade . Try it in a piece of scrap aluminun. You may just learn something . If you don`t do it you want know.Dont let people tell you you can`t do something in a machine shop .You only learn by trying. JUST be Safe.
piniongear
05-01-2008, 08:22 PM
I use slitting saw blades on my Bridgeport.
I run the mill at 600-700 rpms with the blades held on an R8 arbor.
I use HSS plain slitting saw blades of a diameter of 2 diameter.
I have 1/32, 1/16, and 1/8inch thick blades, having no set to the teeth.
These blades go right through aluminum with no problem.
The cost of these blades is $13.85 each.
If you want to move up, you can get a HSS slitting saw w/ side chip clearance for only $45.05 each. (2 inch diameter)
If you want to move up again, you can a HSS staggered tooth saw for $60.65 each. This blade comes as a 3 inch as the smallest sold.
You still want to upgrade all the way to carbide? No problem, you can get a 4 inch (smallest made) with carbide tipped teeth. All 6 of those teeth I might add. This baby will only cost you $131.15 each.
Since my $13 HSS blades smoothly cut the aluminum, I have no need or desire to 'upgrade' thank you........pg
BobWarfield
05-01-2008, 08:31 PM
You mean like this?
http://www.cnccookbook.com/img/OthersProjects/HillmarCarbBlade.jpg
http://www.cnccookbook.com/img/OthersProjects/HillmarCarbBlade2.jpg
Have a look over here, they seem to work pretty good:
http://www.homemodelenginemachinist.com/index.php?topic=166.0
I think he said that was a $7.95 blade.
BW
davidwdyer
05-01-2008, 08:44 PM
The price is certainly right. Also, I am in Brazil and it is easy to find small blades for wood, but complicated to find a real cutter for milling slots.
Also, it seems that one would have to modify the center hole to fit on the shaft.
I wonder what RPM he is running that blade at and whether it would work for steel?
QSIMDO
05-01-2008, 08:52 PM
You mean like this?
BW
(groan) yet ANOTHER project! "Turn arbor for cutoff saw"!
Get thee behind me Bob Warfield!!
h12721
05-01-2008, 09:11 PM
davidwdyer,
I am working on a Stuart triple compound. The cut You see in the picture is a piece from that set. I cut 1018, Brass, Alu, plastic and what ever comes in front of me. On the metal, (1018) I use about 850 to 1000 rpm on a Mini Mill.
on Brass and Alu I go higher. You can feed kind of fast.
The blade is around 0.055 thick. The cut comes out clean and some times you could use it as is. Since I know now how it cuts I set it 0.060 from what I need and take a 0.005 fly cut after. If you cut to slow a speed the blade will sort of clog and it sounds horrible. The chips get caught in the slot. So higher speed it is.
The hole is 15 mm. I made s small insert to use the blade on a 0.5" arbor.
All my metal gets cut with this thing. Will have to make smaller arbor so I get a deeper cut out of it.
Hilmar
