View Full Version : combination bolt
jimmstruk
05-04-2008, 10:13 PM
I recently ran into a new one on me, a double ended bolt, metric on one end and usa standard on the other. The larger end is 3/8 x 16 thread, the smaller end is m8 1.25 JIM
http://i297.photobucket.com/albums/mm207/jimmstruk/shopstuff023.jpg
andy_b
05-04-2008, 10:59 PM
what was it from?
maybe somebody stripped the 3/8" on one side and figured a 8mm was the next size to re-tap it to????
andy b.
HSS
05-04-2008, 11:28 PM
I use double ended bolts to hold a head cooling fan on the head of a refrigeration compressor, but they are standard on both ends. Don't know what would be standard on one end and metric on the other.
Fasttrack
05-04-2008, 11:45 PM
I see those all the time in the auto industry now days. In fact, I've got a handful of those bolts from Dorman.
Paul Alciatore
05-04-2008, 11:47 PM
I made one of those about 40+ years ago. English/metric bolt. Probably different threads, who remembers such details. It was for his car, a Renault. I believe he had a problem with the air filter. Lost the nut. Metric stuff was not that easy to find back then and the dealer didn't have it in stock. So we got a good old US nut and drove happily off into the sunset.
Not an OEM part but it worked. The two worlds do meet so I can imagine some need for this kind of thing.
jimmstruk
05-05-2008, 04:38 AM
Fasttrack got it .That bolt holds transmission to engine, Chevrolet 6.5 diesel pickup truck. That was my first time to see a combination on the same bolt. But I dont often work on small trucks. JIM ps This bolt discovery was about the same time we had long discussion about should we go all metric in the USA?
snowman
05-05-2008, 08:05 AM
Those are FUN!
