View Full Version : OT... what I've Been Up TO With Pictures
Tinkerer
05-06-2008, 01:43 AM
That ON Topic.. ;)
Been working on my fence project the last few weeks got 48 foot built and ready to paint. Popped in at least once a day to keep up with the drama and the projects.
Anyway here's a couple projects I whipped up... need to make a tap and the best way to hold the stock was in a collet. So I made a drawbar for the Old Atlas.
Here's a few pictures.
http://img.photobucket.com/albums/v665/A-Tinkerer/knob.jpg
Here's the handle being turned. It has a 13 bevel to the center hub.
http://img.photobucket.com/albums/v665/A-Tinkerer/drawbarknob.jpg
This is the parts and the completed drawbar. The real fun part was grinding the little 60 threading bar for the 26 tpi bore.
http://img.photobucket.com/albums/v665/A-Tinkerer/drawbar.jpg
Here is the test fit... Works Great.
Tinkerer
05-06-2008, 01:44 AM
And this is a V-Block I made as well.
http://img.photobucket.com/albums/v665/A-Tinkerer/Vblock.jpg
:cool:
dp
05-06-2008, 01:55 AM
I'm going to steal the bird's beak idea on the clamp. It would have solved a problem I had recently.
Nice hand wheel - is that aluminum?
Chip_er
05-06-2008, 08:13 AM
Why the wings on the v-block? :-)
Tinkerer
05-06-2008, 12:37 PM
pd... You mean Pac-man that thing grips like a Scottsman to his wallet... tight and no marring :D. The hand wheel is aluminum with a sheel hub shink fitted in. Then that was press fitted on the tub behind the slip brushing with the 710 hole in it.
Chip_er... The wings are removeable but allows it to be used in a vise. Besides the shaper and mill I've used it in the bandsaw to hold for short cuts.
http://img.photobucket.com/albums/v665/A-Tinkerer/000_0945.jpg
It's 6" long and is handy as heck.
http://img.photobucket.com/albums/v665/A-Tinkerer/000_0944.jpg
And this is a shaper ID cutting bar and holder I made up to use on some bigger parts. The bar is 3/4" necked down to 1/2" so I can use my other bars as well.
