View Full Version : Yeah the Big C Bores Again
madman
05-20-2008, 12:19 AM
I made a mistake in first post . (Figures) The material was 4 inches thick boiler plate or hot rolled,Very abrasive it seemed, Now the counter bored holes were 48 millimeter in diameter, I ended up through hole drilling the pilot 33 mm, and then plunged in with a 1.625 cutter (reduced shank) and then a friend lent me a New 1.750 dia cutter, Finished it by using a boring head and bar, NOW the worst of it was also Hand Tapping the 42 mm by 4.5 mm tapped holes did that ever suck, Later
Mark Hockett
05-20-2008, 02:03 AM
Mike,
It sounds like you worked that Bridgeport to the max capacity and then some.
jimmstruk
05-20-2008, 05:35 AM
Now that we know the rest of the story, (4 inches deep) those holes are getting huge. Those plates were still heavy after removing all that metal. Where did you find a thread tap that size? I did not see a tap nearly that large my last trip to harbor freight. Sounds like you have whipped the job anyway. JIM
