View Full Version : Homemade c -bores
madman
05-21-2008, 09:59 AM
TPG Inserts in a huge counterbore 45 and 48 millimeter ?? Would this be a viable project? I am thinking of building a nholder for the tpg inserts and also wondered what type of clearances in degrees should be machined into the individual pockets if any? Thanx Mike
Chipslinger
05-21-2008, 06:14 PM
Man when go off on something you really go off. 3 threads and it could have been done in one, And I am still no more enlightend than I was after the first few posts on the first thread. :)
digger_doug
05-23-2008, 07:47 AM
http://www.ktoolinc.com/counterbores/standard/c-bore.html
Only using triangle inserts.
Looks easy enough to make.
lazlo
05-23-2008, 12:26 PM
That uses square (SPEB) inserts. You need to cut on the downfeed and simultaneously widen the hole.
