View Full Version : OT - Auto battery charger recommendation?
Frank Ford
05-31-2008, 03:27 PM
My Sears battery charger appears to have croaked after only three and a half decades, so it's time for a replacement.
I'm thinking I'd like to get a bigger one that can charge a flat car battery fairly quickly, but I realize I know next to nothing about these things, so I'd appreciate any and all info about brands and features to look for.
jdunmyer
05-31-2008, 04:40 PM
Frank,
I have a couple of battery chargers bought from Wal-Mart for under $50.00/each. Both work well. Output is about 10 amps, and both have a "boost/start" function that will crank an engine even though the battery is pretty well dead. Dunno if I'd use that on a car with a computer, though, best to simply charge the battery, and not too fast, either. Both have meters so you can see what's happening with the charge rate, also both have a "charge complete" light.
speedy
05-31-2008, 07:46 PM
I presume that your available variety of chargers is larger than ours Frank.
this is the item that I use(borrow) for my charging requirements--Brilliant! but expensive NZ $290 retail IIRC. Then again, batteries are expensive here also. 12v 9 plate= NZ$125 for a reasonable item
http://www.batterytown.co.nz/chargers_intelligent.htm
http://www.batterytown.co.nz/Downloads/intelligent_chargers.pdf
macona
05-31-2008, 08:09 PM
Almost all battery chargers are made by the same company, Century. The same company that makes a lot of the cheapo mig welders and plasma cutters.
So pretty much they are all the same.
jmm360
06-01-2008, 09:58 AM
I've had the good luck with Associated brand chargers:
http://www.associatedequip.com/associated/index.html
Fasttrack
06-01-2008, 04:02 PM
Is Shumacher still around? They used to make some damn good charges. I've got one I pulled out of a landfill (going on 30 years old) and repaired it. Just had a bad connection in the transformer. Its a great charger but it doesn't have an automatic shut off feature, just a timer. It has a 6 volt charger setting, 12 volt maintainer, 12 volt 10 amp, 12 volt 40 amp and 12 volt 200 amp jump setting. awsome.
edit: My dad has two more of these things. They are not nearly as big, they only have a 2 amp and 10 amp rate, but one of them is going on 45 years and still works great.
carlquib
06-02-2008, 12:41 AM
Yep, Shumacher is still in business just bought a new one last year that has a 250 amp boost/start setting. The big one is great for the trucks or to get something started but I still keep several automatic smart chargers around too. Sometimes the big one is to much for a small 12 volt battery.
-brian
