View Full Version : babbitt bearings
dilligaf
06-03-2008, 05:40 PM
instead of babbitt bearings could i use bearing bronze or something else on my new drillpress?
thanks
Jason
garyphansen
06-03-2008, 06:10 PM
Yes. Gary P. Hansen
tattoomike68
06-03-2008, 06:42 PM
Bronze will work fine for a while. Babbit is some slick stuff thats why
it is used at saw mills and even the engine bearing on your car.
Babbit is kick ass stufff..
ptjw7uk
06-03-2008, 06:44 PM
If you could get it in the right size sintered bronze bearings will work as good as babbit and keep some oil in place.
Peter
tattoomike68
06-03-2008, 07:20 PM
Some large machine tools have babbit high speed rapid traverse clutches. its not just a simple as some would think.It works like a champ..
babbit can be cast in place and rebuild driveshafts and spindles to no end with skill, it is an art and an science.
God bless the kids who want to learn whats up....
TheAndroid
06-04-2008, 01:07 PM
Where would someone find babbit to play with? I don't think I'd mind paying for ingots unless they were priced like gold.....
PackardV8
06-04-2008, 01:45 PM
Babbitt
Babbitt in stock Now! Delivery Now. Quality for 28 years. ISO 9001:2000
www.Nuclead.com
n.
Any of several soft, silvery antifriction alloys composed of tin usually with small amounts of copper and antimony.
[After Isaac Babbitt (17991862), American inventor who patented such an alloy.]
thnx, jack vines
Mad Machinist
06-04-2008, 05:43 PM
Only problem is most commercial suppliers require a 50 lb minimum order for true bearing babbit.If some one really want some send me an email or PM and I'll give you a shout. I still have 15 or 20 ingots of it I use to make main bearings on a type of antique engines I rebuild, I can still get rod bearings...just no mains:( so I make my own.:D
The ingots are roughly 2 x 8 x 1 inches and weigh around 4 lbs.
loggerhogger
06-22-2008, 10:51 AM
you can also find babbitt on e-bay. quite often there is a seller that has "Marine engine" grade ingots. I have a couple, and have had pretty good luck.
Quetico Bob
06-22-2008, 04:13 PM
Aluminum bronze seams to be the norm up my way but very expensive, about $16 per inch for 1-1/2 OD x 1 ID. Not up on bearing material but they claim its not strong but very tough wearing.
Cheers, Bob
CCWKen
06-22-2008, 05:53 PM
I've got about 25-30lbs. of babbitt left. It's lead free (< .35%) and is good for mid-range to upper loads. It's used in nearly all antique engine and machine applications. If you want to try some, give me a holler. I have the spec sheet and analysis if you need it.
The pouring temp is just over 900* and is pretty critical so you'll need a way to watch the temp. A pyrometer is about the only way to keep an eye on the temps during the melt. The IR temp readers don't work very well because of the reflective surface.
Ops. I guess I should have read all the posts first. Looks like Mad Machinist already offered. My ingots are about 6lbs. each with about 2lb. partings. A single parting is about 1 x 1.5 x 3". That's from memory so not exact but it gives you an idea of the volume and how much you might need for an application.
