View Full Version : Anyone recognize this Craftsman ac/dc buzzbox?
gellfex
06-04-2008, 07:49 PM
Anyone recognize the model of this Sears Craftsman welder, and do you think it's worth $100 without ground and stinger cables? I want it for my Readywelder MIG spool gun that I've been running off of deep cycle batteries. Most of my welding is 1/8 thick and under steel, 3xx SS & AL.
Any answers to a few more questions would be appreciated:
Do I assume that lever on top controls the amps? How many 220v amps does this thing pull? Since the seller has no cables, I can't ask for a demo. what's the likelihood it's a pig in a poke?
Thanks
http://img.photobucket.com/albums/v358/gellfex/WelderWEBSIZE.jpg
CCWKen
06-04-2008, 08:44 PM
That looks like a newer model than the 250A-AC Craftsman I have. I bought it new around 1985 and it has a lockable horizontal adjuster on top. I've always run mine on a 50A circuit and have never popped a breaker even at the full 250A on 1/2" and 3/4" plate. If the DC works, the diodes alone are probably worth the $100.
Reed
06-04-2008, 09:28 PM
I have one of these. Bought it in the early 80s (i think), burned at about 8, 50 pound boxes of 1/8 7018 in the first few years. I've since purchased a Dynasty 200DX, but can not seem to get rid of the Sears AC-DC box.
I'm a bit biased, but if it works 100 might be ok. I don't think I'd pay any more. :-)
gellfex
06-04-2008, 09:47 PM
Do you guys know any way I can test it with a multimeter, since it has no leads? I don't even know if he has a 220 outlet for it available.
Cables & clamps for this would run almost $60! A new Hobart from Northern for $420 shipped starts to look good if I want to do stick in addition to the spool gun.
Bob Ford
06-05-2008, 12:00 AM
Put the leads from a ohm meter one in each D C cable socket. If the diodes are good you will get a reading. Switch the ohm meter leads and you will get no reading. Diodes allow current to flow in only one direction.
Bob
gellfex
06-05-2008, 10:59 AM
Bob
I guess I don't understand the circuitry, my electronics is pretty rudimentary. Why the diodes would be shorting the poles of the output, wouldn't they be in line on the circuit, leaving a half phase? Or is there simply a leg of transformer between those output poles, so that all that is between them is lots of wire and the diodes? Is there a bridge rectifier in these things?
camdigger
06-05-2008, 11:43 AM
If there is no power available, there are some multi meter tests that could give you some clues, as previously described, the output terminals should give a reading with the leads on the output terminals on one polalrity, but not the other - but this must be done without power as the multimeter is actually measuring a current put put by it's internal battery. trying this check under power may let the magic smoke out of your meter. Similarly, an Ohm check across the inpouts should give a low ohm readings to eliminate the possibility of an open on the input tranformer coil.
If 220 power is available, the output terminals should show a DC voltage across them - about 25 - 30 volts, IIRC. As far as breakers, I think you need a 50 amp minimum and I think about 65 is recommended for a similar ad/dc welder.
AFAIK, 100 $ without leads is the most I would pay for this machine unless it has an internal cooling fan. Internal cooling fans add longevity and value to the unit, IMHO.
Cam
gellfex
06-05-2008, 09:40 PM
It sounds like if I can't power it up, to risk no more than $50 or so.
Damn, at todays copper prices, the 35' of #6-3 armored cable I'll need to wire this will set me back as much as the welder!
Cam
