View Full Version : New Enco mill
mxbob
06-24-2008, 05:39 PM
Hi all, new member with a new Enco mill, the 20" sitting in my driveway in the crate to deal with when I get home. The free freight finally got me moving. I am pretty excited, I have had a lathe for a few years so looking foreward to the increased versatility. I am sure I will have a lot of questions. I am basically a gunsmith and sports car hobbyist. I am glad to have this resource, this seems like a great place with lots of good info freely shared.
Thanks
Bob Ray
Joel
06-24-2008, 07:02 PM
Congratulations on the new acquisition and welcome!
Dawai
06-24-2008, 07:28 PM
Drill hole in floor, drop pin in it, winch mill into garage...
Get it up on rollers? pipes or solid bar stock and roll it a few inches at a time.. can move it anywhere like that..
Keep your fingers on your hands..
http://www.metalmeet.com (http://www.metalmeet.com/) is another excellent place for someone with parallel hobbies to mine...
tattoomike68
06-24-2008, 07:32 PM
get some meat head friends to drag it into place, a case of beer works. make sure the work is done before the beer is passed around.
Quetico Bob
06-25-2008, 07:55 AM
Like David says, 3/4 black pipe and an inexpensive come a long works well.
Cheers, Bob
chrsbrbnk
06-26-2008, 12:09 AM
clean the goop off the ways and all before you crank the table around , it tends to harden up and mess with the lube I took mine all apart to get into the basement and cleaned out some chips and iron dust while I was at it. bridge ports often come with grit in their oil passages the enco was cleaner
MickeyD
06-26-2008, 01:38 AM
Which mill did you get? I am not sure what a 20" one is.
