View Full Version : Unimat PC Motor
iBorg
07-03-2008, 11:50 PM
I have a Unimat PC. Its a nice small lathe compared to other Unimats. It serves my purposes well. Unfortunately, I hurt the motor and need to get it replaced. It is a bit of an off design as the motor goes through the lathe casing. Anyone adapted a different motor to a Unimat PC and would be willing to share with me?
Paul Alciatore
07-04-2008, 12:05 AM
Web search for "Unimat Parts" =
http://www.unimatt.com/Resources.htm
They list several sources. I would try Blue Ridge first as I have used them before and got satisfactory service.
There were other hits if that one does not pan out.
iBorg
07-05-2008, 01:24 PM
I tried Blue Ridge a while ago, they're about an hour drive. They basicly told me that they no longer carried parts for the lathe and could not direct me to a replacment. I guess I'm going to be building some form of adaptation. Now the challenge is to make it look neat enough that I'm not frustrated by a "cobbled" look.
Weird, I'm as interested in looks as performance.
SGW
07-05-2008, 01:47 PM
Random idea: could you adapt a motor from a Sherline lathe?
Quetico Bob
07-05-2008, 02:05 PM
What are the specs on the motor and it’s physical size? A picture would be great. Might give some us a few ideas to pass on. But you might be in the position were you need a lathe to fix your lathe, been there. Nothing weird about wanting something to look just so.;)
Cheers, Bob
viking
07-05-2008, 02:55 PM
i think a trip through the Grainger catalog might be a good place to start to get ideas on where one might find a motor that could be adapted and look original or close to it. They have an online catalog, however many of us prefer to turn the pages.
Circlip
07-05-2008, 03:04 PM
Have you checked for any Yahoo user groups iBorg? Read somewhere that the motor on the earlier Unimat was a pain.
Regards Ian
S_J_H
07-05-2008, 05:04 PM
Do a search, I thought I had read where Evan put a different motor on his unimat.
iBorg
07-05-2008, 07:27 PM
This is what I know about the motor:
Here's what I know about this motor:
80 Watt/ Max Power at 50 W
Reversible
48 volt DC
Power is supplied by a power control built into the body of the
lathe
Motor goes into the frame of the lathe.
Lathe motor is weird shape. It is a plan cylinder with the
following dimensions:
5.374 inches ( 136.5 mm) From tip of shaft to endbell
.639 inch ( 16.24 mm) shaft
.198 inch (5mm) shaft with machined flat
4.78 inch (120 mm) motor casing
1.913 inch (48.6 mm) motor casing diameter
Electricl connections are at the end of the bell casing
Motor is marked VDO Made in W Germany. The numbers 210864 is
marked
on the side in blue ink as well as 4190 in a square.
THANKS!
John Stevenson
07-05-2008, 07:52 PM
This any good ?
http://cgi.ebay.co.uk/Unimat-SL-DB-U90-115v-motor-with-mounting-harware_W0QQitemZ130235234283
Paul Alciatore
07-05-2008, 08:06 PM
Another possibility would be to take the bad motor to a motor shop and see if they can rebuild it. It may be expensive compared to a new motor of similar size but this may be cheaper and easier than locating a replacement and possibly modifying it.
Quetico Bob
07-05-2008, 08:28 PM
SJH, I’m thinking he’s used it for his bike with many mods. Not too often you need to see a lathe screaming down the road at a buck 50!!
Cheers, Bob
Quetico Bob
07-05-2008, 08:48 PM
J S , 48 volt D.C.. Maybe start looking at military surplus. Ships wiper motor? Had a 44’ foot coast guard but still 24v. Pretty sure Mil use higher DC. Any chance Mike you can send a picture?
Cheers, Bob
Yankee1
07-05-2008, 11:48 PM
Hi
My Unimat SL would pop the breaker and when I tested it with an ohmmeter
it showed a ground. I inspected it and could see nothing. To make a long story short I cut about 3" off the cord and refastened it to the motor and its been fine ever since.
Chuck
iBorg
07-06-2008, 11:03 PM
I'll try to post a picture in the next day or so.
I'm wondering if this motor would be reasonable if I choose the replace motor and use a jackshaft method?
http://surpluscenter.com/item.asp?UID=2008062312331625&item=10-1023&catname=electric
THANKS!
