View Full Version : Oxy/Propane?
lazlo
07-14-2008, 01:11 AM
I've read that Oxy/Propane silver soldering (brazing, really) is the cats meow.
I've got two cutting torches, an oxy/acety rig, and the multi-fuel (Kevlar) hoses. Can I use an Acetylene regulator on a propane tank (I know I need the acme adapter)?
Also, Smith et al sell separate propane tips, which are more expensive than normal acetylene tips. Are they really necessary?
Thanks!
Robert
coldformer
07-14-2008, 01:31 AM
the only one i changed was the cutting tip the rest worked ok
jerry
Ian B
07-14-2008, 01:41 AM
Robert,
I'm using an acetylene regulator on a propane bottle - works fine. I had to machine up an adaptor as the threads were different, otherwise no problems.
I think the propane nozzles have larger gas passages than the equivalent acetylene ones, so yes. you'll need proper propane nozzles. Otherwise, for what I need it for, oxy/propane is brilliant. I'd far rather keep propane in my workshop than acetylene. Cheaper, more widely available, less unstable.
Ian
Fasttrack
07-14-2008, 01:44 AM
I'm no expert (understatement) but I've used both for cutting and brazing. (Although brazing is still a new "art" for me)
I always heard that the hottest part of the propane flame is the "sheath" around the inner core. For the acetylene flame, the inner core is hotter. Different tips and slightly different technique are needed.
I personally prefer propane (of course thats what I learned on) but it can cut much thicker material than O/A and does a better job of heating large items for brazing ... like certain cracked pacemaker castings ;)
Now before anyone jumps in and starts tossing around the "but acetylene is hotter" gambit, its maximum temperature burning in oxygen is 5720*. However, the maximum temperature of propane burning in oxygen is 5110* (both in Fahrenheit), although most values for the oxygen propane flame put it at about 4200*
More importantly, however, propane produces nearly 1000 btu/hour more heat than an O/A torch - which means better pre-heat and better heavy cutting. (although arguably less control for those "precise" gas welds)
Anyhow, looking at the two tips and considering that that stoich ratio for propane is 4.3:1 and the stoich ratio for acetylene is something like 1.2 or 1.3 to 1 (iirc), I think that you really do need the propane tips.
p.s. - propane can't be used for welding, though. Don't ask me how I know ;) Apparently it doesn't produce as much C02 as Acetylene does, so there is no shielding effect. I couldn't figure out how gas welding was supposed to work when all of my puddles just burned right up, then someone told me about that CO2 thing, and it all made sense! :)
Argh - everyone beat me to it! :D
doctor demo
07-14-2008, 02:13 AM
Thanks!
Robert
The propane tips have different orifices than acetylene tips, and I think the mixer is different also . If You can purchase an adapter from Your local welding store than I would say yes to the regulator question. But why buy propane and tips and adapters?
Mapp gas is right below acetylene (heat wise) and propane and nat. gas are right below that , so to do the same amount of work it takes more gas so why switch? Just use a smaller acet.tip with the rig you already have.
I guess I should learn to type faster and not watch TV at the same time !
There were no replies when I started.
07-14-2008, 02:24 AM
Propane is the cheapest way to cut scrap,not the neatest cut,but cheapest.It does however cut good in a machine torch application.
Propane is better on thin materials where you do not need super high heat.Solders,fluxes and braze metals can all easily be overheated.
Yes the tips are needed since the oxy/fuel mix ratio is diffrent.
Another handy use for a propane bottle and reg in the shop is crude heat treating.A propane burner and a stack of firebrick makes a good furnace for quickie heat treat jobs.
07-14-2008, 08:55 AM
One little problem with that. It's illegal to keep propane in your shop. The reason is that propane is heavier than air and when a leak occurs the unmixed propane will collect in the lowest part of the shop. As long as there isn't a good source of ventilation it can lie there for a long time waiting for ignition.
The instability of acetylene isn't a common source of problems since it is dealt with in the design of the apparatus that uses it. If it leaks it mixes with the air since it is almost the same density (very slightly lighter) and doesn't collect on the floor like a land mine. It take a much larger acetylene leak to pose a problem than it does with propane.
Propane has several issues besides the safety aspect. It's good for heating but sucks for welding and as Darin said makes a more ragged cut. The reason for that is because the majority of the heat in a propane flame is in the outer envelope instead of the central core. This is what makes acetylene a "hotter" flame than propane. It delivers the majority of it's BTUs in the central flame in a much smaller area than propane can. The reason for that is that acetylene has a very wide range of mixture that will combust whereas propane is limited to a very narrow mixture range. Propane requires much better mixing before it will burn. Propane is not well suited to delivering heat precisely when heating for the purpose of bending for instance.
That brings up another point. While it is possible to use propane in some unmodified acetylene equipment at sea level such as an acetylene/air torch it stops working with only a minor increase in altitude as the mixture becomes too rich with decreasing oxygen partial pressure.
lazlo
07-14-2008, 01:07 PM
Thanks for all the responses guys!
That's exactly what I'm looking for -- I'm doing fine silver soldering, and even with a number 0 acety tip, it's easy to overheat small parts.
OK, that helps a lot. I don't know what a stoich ratio is Fasttrack, but I'll take your word for it :)
So is a Number 0 propane tip the same size as a number 0 acety?
That was my other reason for wanting to add propane to the shop: I bought one of Stephen Thomas' prototype camelbacks, and it wasn't stress relieved. The local heat treat shops want $75, so I was thinking of just making a pile of firebrick to heat the casting to 1100F.
I need to get a Harbor Freight weed burner...
07-14-2008, 01:36 PM
Ditch the weed burner,build one of these-
http://metalcast.boorman.us/reil_1.html
You will also need a high flow regulator,think turkey frier,Homedespot and Lowe's used to sell them seperate.
Oh,if you want to stress relieve all you need is a sheet metal box big enough to hold your casting and a roll of Kaowood or Fibrofrax wool.Look up 93315K34 at http://www.mcmaster.com/
It's great stuff to have around,checkout Ron Reils freon tank forge-
http://ronreil.abana.org/minifor1.shtml
Fasttrack
07-14-2008, 02:10 PM
stoich is short for "stoichiometric" - which is basically the ratio between the two (or more) components in a chemical reaction. For combustion, you might have C3H8 + O2 = CO2 + H2O and then you'd balance the equation, coming up with:
C3H8 + 5 O2 = 3CO2 + 4H2O, so the stoich ratio in moles would be 1:5 for propane. The molar stoich ratio for acetylene then, is: 2:5
2C2H2 + 5 O2 = 4CO2 + 2H2O
Basically, you burn more oxygen per mole (or per any unit quantity) of acetylene than per mole of propane.
Acetylene is an interesting gas. With a tripple bond between two carbon atoms it's rather interesting on the atomic level. Incidently, its that tripple bond that makes it unstable.
I dunno - maybe you already knew what "stoichometric" was. I don't think stoich is a recognized abbreviation, come to think of it. Just what all the chem guys say 'cause they're too lazy to pronounce "stoichiometric" :)
Swarf&Sparks
07-14-2008, 02:25 PM
nup
the stoics use C2H5OH
Coppretta
07-14-2008, 05:16 PM
Oh, that's good to know that it's just the fittings that are different
for Ace or propane.
I was told they needed different regulators but I never thought to ask why.
topct
07-14-2008, 05:30 PM
My gas gauge screws right into a 20 pound tank.
While we are on the subject of propane. Has anyone tried it with a fluxer?
lazlo
07-14-2008, 05:57 PM
Oh, that's good to know that it's just the fittings that are different for Ace or propane.
Your local welding supply will have the acme thread -> NPS adapter for around $30.
07-14-2008, 09:45 PM
for Ace or propane.
Not quite. Brass made for acetylene use must not contain more than 65% copper and only bare steel or the correct brass fittings should be used. In particular, copper plated fittings can cause acetylene to explode at any pressure. While it is safe to use an acetylene regulator on propane it is NOT safe to use anything but an acetylene regulator on acetylene.
Herm Williams
07-15-2008, 12:46 AM
Other than cutting tips acy/oxy and propane/oxy function the same. I have never tried welding but brazing, soldering, cutting use the same regulators. We have a cutting table that uses up to six torches to cut from ten gauge to six inches thick material. For me propane or natural gas heat is more controllable for small silver soldering.
re
Herm
lazlo
07-15-2008, 12:49 AM
Thanks Herm (and the rest of the guys) - that's exactly what I'm looking for: fine control for small model-engineering sized silver brazing.
I ordered a 00, 0, and 1 brazing tips for my Smith AW1A from Cyberweld. They didn't stock the propane converter, but I'll get that at airgas. I'm sure it'll be cheap :rolleyes:
tattoomike68
07-15-2008, 01:47 AM
If thats true it may save someone a bad day, thanks for the info..
07-15-2008, 02:03 AM
Safety
Acetylene mixed with air or oxygen in a confined space will explode when ignited. Acetylene decomposes explosively if piped at pressures above 15 psig and exposed to mechanical shock or ignition source. Acetylene forms explosive compounds with copper, silver and mercury. Use steel pipe and fittings and pressure gauges with steel or stainless steel bourdon tubes. Copper alloys if used must contain less than 65 percent copper. Acetylene has a very wide flammability range in air of 2.5 percent to 81 percent by volume. Also very low energy sparks such as static electricity can cause ignition and explosion.
http://ilmoproducts.com/fuel.html
BadDog
07-15-2008, 03:54 AM
Robert, don't you have a Midget? They've got tips for that sort of thing using any fuel you want. Mine has LP, Ace, and NG tips...
lazlo
07-15-2008, 11:22 AM
Hi Russ, no I don't have a Meco -- I braze with a Smith AW1A aircraft torch, which I really like. But thanks for the offer!
