View Full Version : Peristalticpump hose?
sdeering
07-14-2008, 08:51 PM
I'm pondering making cement/stucco pump.
Anyone know what type of hose would work the best in this application? Im thinking 1to2".
All I have found Googleing is, it is made of open-cell polyurethane, has a combination of outer fabric reinforced shells with inner “rubber” walls that have a tremendous “memory”.
I will be applying 1” of stucco to the inside and outside of a 30x40x17 foot straw bail building. I don’t want my one arm to be twice as big as my other at the end of summer.
I have been experimenting with am essic progressive cavity pump, I think designed for fire barrier material. It works but I don’t think it will do the 17’ of head needed.
Thanks for any help.
Stephen
Guido
07-14-2008, 10:19 PM
Progressing cavity pump styles come in many flavors, ie. pressure vs volume. Great for moving abrasive/fluid slurries. Pressures to 17 feet of head are 'no chore for a stepper'.
For moving cement based stucco materials and mixing with water, Google up Reed Concrete and Gunite Pumps. Depending on where you are, weekly rental of a pumping system and compressor for a one off job, will greatly simplify your project.
I hesitatate to suggest it, but more than one working gunite machine has been cobled together by those so inclined.
G
sdeering
07-15-2008, 12:26 AM
http://www.southern-tool.com/pdf/multiquip/broch-essickminsprayer-1099.pdf
This is what I have actually 2 of them, except for the hose and wands.
I am using a 3/4" hose and I built a wand. I am using air from my shop comp. I think the stator is wore out. If I put my hand over the end of the hose and stop the flow.
I think I am mixing my plaster thin enough. Its not pluging it just has poor flow.
I was thinking of renting something but there is nothing in my part of the province.
Since I have the wand hose and air I think building a parastalic would be quite simple, except for the hose material.
Anyone else?
Stephen
doctor demo
07-15-2008, 01:18 AM
Anyone else?
Stephen
Delta Rubber sells all kinds of conc. pump hoses here in Calif. I don't know how big a footprint they have globaly though.
Push come to shove You could call and get a hose spec. and go from there.
sdeering
07-15-2008, 01:24 AM
Thanks DR. nemo
digger_doug
07-15-2008, 07:47 AM
something like this ?
http://static.monolithic.com/gallery/equipment/ghp-2500/index.html
sdeering
07-15-2008, 07:57 AM
Yep. I have browsed that site watched the vid too. The guy has some great ideas I like the bobcat mixer.
Hears a pick of his hose. i could order from him but I would rather find somthing in my area.
http://shop.monolithic.com/products/peristalticpumpline
I’m thinking a smaller version.
I may have to go to our hose supplier and have a look.
Stephen
