View Full Version : A machine shop Master card commercial
loose nut
07-28-2008, 10:04 PM
This was my last weekend work,
*Milling a jig to hold the work at the proper angle and setting it up--4 hours
*Realizing that the angle is wrong and beating my head against the wall--15 min.
*Re-milling the jig to the proper angle and setting it up--4 hours
*Time to actually machine the part, less than 5 minutes--Priceless
Why do we do it?
Bmyers
07-28-2008, 10:12 PM
my Friday night
Time to pull headstock from P&W lathe: 3 hours
Time to machine and heat treat new feed dawg: 1 hour
Time to reassemble: 2 hours
Time to take apart and put back again after dropping last screw in oil sump: 3 hours
Have all the feeds for my lathe for the first time in 20 years: priceless
Mcostello
07-29-2008, 09:52 PM
Finding out that Locktite retaining grade green does not hold with death grip-priceless!
Teenage_Machinist
07-30-2008, 03:30 PM
This could be for some sort of chuck maker....
Set-Tru Backplate: $$$$$$$$
ER collet set: $$$$$
Hiring a high school kid to re-center jigs: $$$
Machining both ends of a piece of scrap steel concentic: priceless
