I just finished the ring roller by Otto Bacon in the Machinist Workshop Vol.20, #6 issue. Its something i've wanted to make for some time now, and finally did it, plus i wanted to make the armillary sphere. A few things to note, i had to make my own pillow blocks and i couldn't come across the wrist pins he used for the shafts, so i made my own. Its got 2" rollers, 1" shafts 1" bearings. The adjustment bolts i welded in place instead of having them float. I used a heavier base because i already had it on hand and. On the flat of the channel, its 1/2" thick, so this thing has got some weight to it. Check the link for the pics. And it works just great.
Finished Ring Roller
Very nice indeed!
You demonstrated admirable patience and restraint in doing a very nice paint job before putting it to work.
Please show us some pics of the finished work when you get around to it.Milton
Very nice looking piece of work. I like the neat and complete finished look. When you get to use it would you please share with us the results.
good job
Mel_____________________________________________
Oregon Coast
Nice!! I especially like the way you incorporated the reduction drive with the handle and sprocket at the end of the roller. That really makes it look good and saves some space, too.
Does the shaft go all the way through, or is the sprocket on a bushing/bearing at the end of the roller shaft?
RogerLast edited by winchman; 08-28-2008, 03:49 AM.Any products mentioned in my posts have been endorsed by their manufacturer.
Originally posted by winchmanNice!! I especially like the way you incorporated the reduction drive with the handle and sprocket at the end of the roller. That really makes it look good and saves some space, too.
Roger
I also vote for some examples!
Seriously though, that is very nice work. I see you stuck a flag sticker. You should also sign it or at least stamp your name on it. I buy some shop-made tooling every once in a while. I actually like knowing the name of the guy who made it...even if that person is no longer with us. It seems a tie to someone who was a real craftsman. A date would be a nice touch too!
PaulPaul Carpenter
Mapleton, IL
