Hi,
I was adjusting the tool rest on the grinder when it accidentally touched the wheel while it was spinning down. The tool rest is made of aluminum and my brand new wheel is loaded with aluminum.
How do I remove the aluminum from the wheel? I've tried using the dressing wheel, but it didn't do much. Perhaps I need to go at it aggressively? Can I soak it in phosphoric acid and dissolve it or will this compromise the integrity of the wheel?
