Well, we have been beating ourselves up a lot lately over politics, healthcare, and other things that we really have little control over. I figure that now is a good time to start a good barroom brawl over which lathe is the best manual home shop machine. I doubt that a consensus can be reached, but at least it will be fun and nobody will lose an eye.
I am going to start by nominating the Clausing Colchester Triumph 2000 15x50 for the following reasons:
- Threads inch, metric, module, and diametral threads without fishing around for change gears.
- 7.5 HP so you have enough power to get aggressive if you want.
- A brake that works.
- 25 to 2000 rpm spindle speeds with a common camlock spindle.
- Heavy enough to make parting simple.
- 2.125 inch spindle bore.
