View Full Version : Horizontal Band Saw
pepecon
09-20-2008, 09:46 PM
I have an inexpensive horizontal band saw from Enco. I started to get problems with the blade binding and stalling . I was trying to saw a piece of round aluminum stock about 1 1/2 inch OD. Also tried sawing steel stock. I was using a 4 tpi blade for the alumi;num and 14 tpi for the steel . I did not know if I was having blade or alignment problems. I took all the blade guides off and want to realign them from the beginning. My thinking is to install the blade , run the band saw to track the blade. then install the blade guides at this position. I did this and still and the blade still binds and stalls in the work. The guides were set to just touch the blade. Am I approaching this correctly ?? I have not yet tried a new blade. The blade is 64.5 inches long and one half inch wide. The blade guides are all ball bearing.
Bill Pace
09-20-2008, 10:32 PM
The motors on these little saws are notoriously weak --- and since your description of blade align/adjust/blade choice sounds like it was done properly the next likely candidate is the motor. There have been a few scattered instances of the little gear box binding up, but much less likely than the motor. Is it new? Enco is great with customer support...
A note of caution: if you have to replace it, be aware of the counter-clockwise rotation (dont ask why I say this:o)
09-21-2008, 01:29 AM
Just asking the obvious,is the belt tight?
I would also check the lube in the gearbox,I have seen those shipped dry and the gears ground to dust before anyone noticed.
Ernest Kerr
09-22-2008, 05:46 PM
I had the same problem until I installed a hydraulic piston restraint like below:
http://i28.photobucket.com/albums/c220/ehkerr/893e.jpg
You will appreciate the experience of other owners if you join the Yahoo Group: 4x6bandsaw
They have several good mods to improve the saw.
Ernest Kerr
09-22-2008, 05:55 PM
The black piston is what I am referring to. The white bucket is for a coolant to cool the work and wash away the metal debris. The piston is adjustable to control the weight bearing down on the blade.
Doc Nickel
09-22-2008, 06:16 PM
Where does one get a piston like that? I have an old Carolina horizontal saw (hey, it was free) and the original damper is worn out, and was probably severely undersized to begin with.
I haven't been able to find any sources for just a damper like that.
Doc.
ecortech
09-22-2008, 07:15 PM
Doc
I have seen the cylinders on ebay. The 7x12 saws use them several ebay venders sell them as spare parts.
Ed
ecortech
09-22-2008, 07:27 PM
Heres one
http://cgi.ebay.com/ABHC-712-HYDRAULIC-CYLINDER-ASSEMBLY-7-X-12-BAND-SAW_W0QQitemZ270272160620QQihZ017QQcategoryZ25290Q QrdZ1QQssPageNameZWD1VQQcmdZViewItemQQ_trksidZp163 8Q2em118Q2el1247
