do you typically use a collet (R8) to hold the drill bit, or do you chuck the bit up in a drill chuck ? The reason I ask is it seems a collet would be more concentric and afford a couple more inches Z room. But, drill bits usually have embossed writing on the shaft which might bugger up a good collet.
Thanks,
Gary
Thanks,
Gary
