If you have an old Ford tractor, in my case a 1951 8N, you soon discover what a pain it is to lose hydraulic pumping when you depress the clutch. This has been addressed with two systems; a pump running off the front of the crankshaft for a front loader and a hideous retrofit belt driven pump called a Live Thang for about $500.00.
Here's my thinking. Build a hydraulic power pack from a 12 volt starter turning a power steering pump actuated by a switch on the clutch petal or a trigger on the lift control lever. A master switch to lock out when not needed. There is access to the tractor pressure side and return so minimum plumbing would be needed if located under the right side of the seat. The Live Thang parallels the auxillary pump with the existing and I know that this works. Would need a battery cable to the pump which wouldn't be difficult.
The existing system develops 1700 psi at about 2.5 gal per minute. The tractor uses the same fluid as the transmission, rear end for the hydraulics. I never had any experience with a power pack. For RPM and power would direct coupling between the starter and pump be reasonable.
Thanks in advance and let the games begin.
