View Full Version : identifying brass or bronze?
thistle
10-14-2008, 10:20 AM
I just got a load of brass or bronze flat bar,that came out of an old chandlery- ie a place that sells equipment for boats,
I didnt get any paper work certs with this as it is old and the company out of business, this should be a marine type bronze alloy , but before i go sticking it near anyhting marine , I need to guesstimate what it is , so does anybody have any idea as to identifying yellow metal alloys?thanks
Herm Williams
10-14-2008, 10:51 AM
Suggest you try your local recycleing yard. At least in my area they will tell you the composition of the metal (very little cost if any). or you can send in a dime size piece to get certs (thirty five to eighty dollars).
re
thistle
10-14-2008, 11:31 AM
am in the middle of nowhere,there is no recycling or scrap....
be interested in finding out who would analyse the metal, from a sample in the US .
barts
10-14-2008, 12:22 PM
A real analysis is likely expensive... but you can get a good idea w/ a bit of home chemistry. Check out http://recyclebiz.com/DoD%20Metal%20Testing%20Manual.pdf for some useful tips....
- Bart
boslab
10-14-2008, 05:11 PM
admiralty brass, aka dzp brass would be my first bet try 'LDM G563'
regards
mark
[its an alpha brass with a smattering of Sn to keep the effects of salt at bay]
the density can be calculated, thats a reasonable guide if you have a balance available, colour is a clue look up copper phase diagram on wiki
dockrat
10-14-2008, 07:51 PM
- Bart
Ohhhhh! thats a good one to have for us novice guys.....thanks :)
thistle
10-16-2008, 10:55 AM
yes thanks for that
