Anyone know of a good source for the 1/4-28 threaded drills and counter sinks as well as piloted counter bores?
Aircraft drills/countersinks?
Haven't seen any threaded shank stuff, but MSC www.mscdirect.com has a couple hundred pages worth of drills, countersinks, and counterbores in their catalog.
If you are familar with the aircraft industry, then try any of the well known suppliers. For tools, I used to use U.S. Air Tool Company (USATCO), Aircraft Spruce and Specialty, Wick's Aircraft Supply, etc. You might do a search for these companies as I would assume they all have websites. To buy cheap and in quantity, Oshkosh will be beginning shortly. This stuff is usually available both new and used for cheap. If you know someone going to Oshkosh, give them a shopping list. All the suppliers I mentioned will be there as well as all the "fle market" types.JHC Dayton, OH
