I saw one.. broke it I did.. yep.. I break plenty of tooling, nobody said I was perfect.
A quarter inch wide tool, with a dip right behind the cutting edge on the top side, as the tool raked the metal it cut curls.
I have not been able to reproduce it.. Been trying to.. Is there any key to this I am missing? Does it need to be polished in the dip? Hand Stoned on the front edge??
I've been cutting keyways on my southbend 7.. they are chattering and leaving a rough finish. I am running as slow as I can and got a good edge, it throws tiny needle swarf thou, not curls.
Tooling holder is a old boring bar to hold the 1/4" tool steel.. about six inches long, clapper box removed and adapter bushing stuck right in the ram swivel and locked down. Boring bar is 5/8"..
Madman suggested I cut the cutter width down to 1/8" wide at tip.. machine is too weak? or?? Perhaps boring bar is too flexible..
This is the fourth or fifth tooling holder I have made for the southbend, this one works best.. so far.. I am on about my tenth keyway with it..
