View Full Version : Help ID a watchmaker's lathe?
Doc Nickel
07-27-2003, 02:48 AM
Pics can be found here (http://www.network54.com/Hide/Forum/message?forumid=9013&messageid=1059273881)
It looks to me like the usual compact watchmaker's or jeweler's lathe, but I don't know much about them other than what a few knifemakers used to say about 'em. (IE, they were cheap, small- which was great for making pins and small pieces for knives, plus saved space in cramped shops- and pretty accurate.
3J collets, if I'm not mistaken?
Thanks for your help.
Doc.
abn
07-27-2003, 09:04 AM
If no one can help you you might add it to the "unknown lathes" page at lathes.co.uk. Sorry I can't be of more help.
http://www.lathes.co.uk/unknown/index.html
G.A. Ewen
07-27-2003, 10:14 AM
A real beauty! But has someone been turning WOOD with it? http://bbs.homeshopmachinist.net//eek.gif ( wood; the nastist four letter word http://bbs.homeshopmachinist.net//biggrin.gif )
Oso
07-27-2003, 11:33 AM
It's German (Frankfurt am Main) and it isn't a traditional watchmaker's style machine. More like a Levin style machine.
Most watchmaker's lathes have a single foot, and a rest for using gravers. The crosslide is usually an accessory and often not present. Sometimes the tailstock isn't even present.
Great for making pins and other odd round things you can barely see.
Should be able to find a taker if you don't want it. Wouldn't mind a thing much like that myself.
Boley watchmaker's lathe (example of typical watchmaker type)
http://www.lathes.co.uk/boley/page3.html
Thrud
07-27-2003, 07:20 PM
Doc
Never got a good look at the collets for size, but most watchmaking lathes use WW series collets, chucks and faceplates. If they are about 1/2" diameter at the large end and a threaded shank it is probably WW. If it is WW you can buy collets and accessories from Lapidary suppliers. I have a number of Grobet WW saw arbors so if you need dimensions let me know.
Alistair Hosie
07-29-2003, 05:07 PM
Doc The name of the manufacturer is Wolf Jahn a well known German manufacturer it says so on the lathe bed you will find if you look up google etc some info on this company they made milling machines as well as lathes.Alistair
Oso
07-29-2003, 06:39 PM
Good on you. Alistair, I misread the label in the pic as "Walt." as in short for "Walther".
[This message has been edited by Oso (edited 07-29-2003).]
Alistair Hosie
07-29-2003, 07:42 PM
no probs glad I could help.Alistair
