torker
11-27-2008, 10:13 AM
For you home shop guys out there...who are fighting this...and getting frustrated..
A thread here brought out a bunch of advice...mostly it came down to "Practice, practice, practice".
Just to let you know how true that is..
The British Columbia Welding Program has probably one of the best "Entry Level" weldor programs anywhere.
There are two different routes to take.
If you work for a shop that will back you as an apprentice. You take a 6 week entry level...then into that shop for a year..and so on for 3 years.
"IF" you get lucky and are under a good journeyman who actually has time to teach you...you will be a good weldor someday.
The other way...the "Class" system is the best IMO.
We have..entry level..."C" class. Then on to "B" class after one year of certified "C" hours (Combined school and work time). The same as you move on to the final "A" class.
"C" class training is very rigourous. It lasts for 7 months.
The kicker...you spend about 4 months...8 hour days...stick welding.
There are a stack of books...containing all the welds you have to pass in this time. They are all destructive tested. You have to pass each weld before you can go on to the next. I've seen guys stuck on the same weld for up to 3 weeks. They don't cut you any slack.. it HAS to pass the bend tests.
So picture that... 4 months...eight hour days...steady stick welding in all positions with almost any rod you can think of. Under pressure the whole time because you HAVE to pass the tests.
Some of these welds are HUGE...there's one that you have to do many times. It's the dreaded "T" bar welds. You end up pumping over 30 pounds of rod into these. They get so hot they can burn the skin off your hands. They make you really question your sanity.
Then you walk out of there with your diploma...and nobody will hire you because you STILL don't know how to weld.... and you really don't. In real life there are so many variables that even intensive training can't cover it all.
My point...the home shop guy who burns a few rods a year...and gets down on himself...really shouldn't.
It's a lot harder than you think.
Russ
Russ
