View Full Version : replacing guide ball bearing on 14" bandsaw, need anything special?
gellfex
12-16-2008, 01:10 AM
I was going to order a plain vanilla shielded bearing from McMaster for replacing the blade guide rear bearings in my Delta 14", but wondered if maybe the plain old bearing that was in there wasn't right to begin with when I bought it at auction.
There's sites selling bearing specifically for this for 3x the price, but I assumed that's the sucker price, not a different product. Any problems with this item for the job?
Part Number: 5972K326
$4.00 Each
Type
Ball Bearings
Ball Bearing Style
Double Shielded
Ball Bearing Type
General Purpose
System of Measurement
Metric
For Shaft Diameter
10 mm
Outside Diameter
30 mm
Width
9 mm
ABEC Precision Bearing Rating
ABEC-1
ABEC-1 Precision Rating
Regular
Bearing Trade Number
6200
Dynamic Radial Load Capacity, lbs.
1,340
Dynamic Radial Load Capacity Range, lbs.
1,001 to 1,500 lbs.
Maximum rpm
24,000
Maximum rpm Range
15,001 to 30,000
Temperature Range
-4 to +248 F
Bearing Material
Steel
Shield Material
Steel
Specifications Met
Not Rated
Note
Grease lubricated.
Ken_Shea
12-16-2008, 01:28 AM
No need to spend a lot of time researching these gellfex, plain is fine.
Have replaced them on cheap and quality saws, plain old shielded bearings.
Ken
Stepside
12-16-2008, 11:55 AM
Get a pair and replace the upper and lower bearing. Take the "best" of the old bearings and wire it to the saw as a spare when one of the new ones gives up many years down the road. While you are taking things apart make sure to clean and adjust the complete guide system. I remove the table for this operation. My preference are Rock Maple guide blocks and stoning the back of a new blade when installing it. I make a stick of block material with the table saw and cut a pile of them ready for use.
