View Full Version : Die head and Rotary Broach Newbie
electromech31
12-17-2008, 05:32 PM
Just quoted a job that needs a diehead and a rotary broach to make it worth doing. I green to both tools. I did purchase a Taco Diehead that is the size I need for Ebay. But a I have not found any info on a rotary broach. Any advice?
Teenage_Machinist
12-17-2008, 05:35 PM
"rotary" broach?
SOme people here could probably help but I suspect a windfall of info would be had at PracticalMachinist.com
electromech31
12-17-2008, 05:38 PM
"PracticalMachinist.com"
I get very little feedback from that website. So I thought I would try here.
Ken_Shea
12-17-2008, 05:56 PM
Lots of variables to Rotary Broaching", best to call a manufacturer on that, it is not inexpensive.
Looked into it and they were very helpful.
I contacted http://www.rotarybroaching.net/
FatWheels
12-17-2008, 06:05 PM
Do a search on rotary broach here in archives. Frank Ford posted a very well documented (as always, with the best technical photos on the board) article on making his own rotary broaches. Hope this helps.
I took my own advice and couldn't find the post I just knew was there. So . . . I surfed on over to his website and got the link. Here it is, hope this helps more.
http://www.frets.com/HomeShopTech/Tooling/BroachMaking/broachmaking.html
regards,
Jim
(edited to include link)
electromech31
12-17-2008, 06:44 PM
Thank you
The link to how to make a rotary broach was awesome. I had been thinking if that would be a option I only have to make 5 pieces in 303 SS, with a 3/8 Hex broached.
Mark Hockett
12-17-2008, 11:29 PM
I have a Slater rotary broach. Here is a link to a video,
http://www.slatertools.com/video.htm
They work well and are very fast but expensive.
DR
12-18-2008, 04:03 AM
You can rotary broach directly using the broaching tool by offsetting your tailstock and hand cranking in. Slow compared to using the special head/tool holder, but works if only a few pieces to do.
peter08
12-26-2008, 05:05 PM
Nice tip! I've been wondering how well that works.
DR
12-26-2008, 05:26 PM
Thank you
3/8 hex in 303SS,factoring in the cost of head and broach, you should have quoted about $150+ per hole. Unless you're counting on many more similar orders it would be best to farm the broach work out.
Don't forget blind broaching can be done just as easy or easier in a press.
