View Full Version : Flux Question
Boucher
12-22-2008, 10:37 AM
I inherited a good supply of silver solder from a friend that was in the refrigeration business. What kind of flux do I need? I have small amounts of two kinds of flux from Brownells. I think one is low temp and one high. Would this work in a pinch on non critical parts?
rode2rouen
12-22-2008, 12:14 PM
Check out: http://www.harrisproductsgroup.com/consumables/fluxes.asp
I used Stay Clean liquid for a stainless mesh radiator guard on one of my bikes......works well. Your LWS should have it in stock.
Rex
davidh
12-22-2008, 12:40 PM
ive been using welco paste for normal silver solder work. when it dries out a bit in the plastic tub, just add water and stir.
temps good from around 800 to 1600
its not for alum, mag, etc,
ahidley
12-22-2008, 01:14 PM
davidh, Are you saying that you can silver solder aluminum and magnesium?
macona
12-22-2008, 03:53 PM
If the silver solder is sil-phos then there is no flux needed.
davidh
12-22-2008, 04:35 PM
no, just referring to the walco info on the flux. . . . .
but it would be great.
hwingo
12-23-2008, 12:55 AM
Believe it or not, Twenty Mule Train Borax soap makes a good flux when using silver solder on Stainless Steel. Mix soap powder with water to make a paste, apply, and solder. I've used this a lot in the past on knives and orthodontic appliances.
Harold
Boucher
12-23-2008, 09:03 AM
Never thought of the soap. The old flux that came in the yellow can for brass brazing and gas welding was borax powder. It was good at high temperatures never tried it with silver solder. The LWS was open yesterday so I got what I needed. The link to the Harris Site was particularly helpful. After the stroke there are things that I know or have known that I just can't put together anymore. I do appreciate the help and information.
vBulletin v3.5.4, Copyright ©2000-2010, Jelsoft Enterprises Ltd.
