View Full Version : Buffalo 18 drill press
Richard J
12-24-2008, 11:27 AM
Picked up a Buffalo 18 drill press few months ago-worked fine when took home but decided to do some restoration work on it-mostly cleaning, repainting etc. Also changed motor and pulley to slow it down a bit. It is a beautiful older machine with a head that cranks up and down as well as the table crank, originally had a foot lever as well but while the gear and lever and column support are there, the lever is not. The main problem is the quill moves up and down about 1/4" so drops thru a hoel as a bit breaks thru plus the quill will not return though i repaired the broken spring and there is black oil dripping thru the spindle [and throwing]. Is there info on how to repair the heads? Have ordered a manual but supect it will have no info on repairs
Richard J
thistle
12-24-2008, 04:22 PM
pictures might help !
