Errol
12-24-2008, 11:56 AM
Up till now I roll outside to do my cutting because of the smoke. But in this cold weather, minus 25 degrees for the past two weeks, I'm working inside the shop.
I have a Spectrum 625 with an Amp range of 15 to 40. I'm cutting up some 4' x 8' x 1/8" steel plate and the smoke is pretty bad.
A few years ago I had phoned the dealer about where to set the Amp control. He said just set to Max and leave it there. So that's what I have been doing until now. Fine outdoors, but not indoors.
So with a little experimenting, I tried lower Amp settings, and seem to cut with less smoke, but eventually there is a trade off. Lower Amp setting seems to produce less smoke, but then the time increases to the point that there doesn't seem to be a benefit. i.e. less smoke/second x more seconds = same quantity of smoke.
I eventually got it set it at 35, and get pretty quick cuts with none of that black/yellow smoke that you get at 40.
Question: Is there a "rule of thumb" for Amp settings vs smoke output?
