View Full Version : HF 1440 wiring
radkins
12-27-2008, 04:03 PM
I got my lathe set up in the shop today and wanted to get it wired in but I am unsure about this so I thought I would see if I can positively identify the connections. In the connector box (3 phase, 3 HP, 240V) the 4 terminals are labeled as follows,
R (black), S (blue) T (red) PE (green)
I will be using a static phase converter temporarily and I have a pretty good instruction sheet with it but I still need to make sure of the connections on the lathe itself. Any info on this would be greatly appreciated.
barts
12-27-2008, 04:19 PM
The green is very likely the ground, the others are the three phases (which is which doesn't matter). Double check this w/ a ohmmeter; there should be infinite resistance between ground and any of the phases; there will be some resistance between any of the phases.
If the motor runs backwards from the way you want, switch any two of the phases.
- Bart
radkins
12-27-2008, 04:26 PM
That was fast!
