View Full Version : Brazing aluminum can?
john917v
01-11-2009, 03:12 AM
What would be the best way to affix some aluminum fins to a Monster Energy drink can? I don't have a tig welder, or a multi-gas torch, just a soldering iron, and a propane blow torch. I'm also open to using an adhesive. It's going to be a radiator for a water-cooling system for my Unimat lathe motor.
macona
01-11-2009, 03:56 AM
Epoxy would be best, but they will only be decoration. There will be nill heat transfer. Get a water cooling kit for a computer. Has all the parts you will need.
Why in the world do you need to water cool a Unimat lathe motor?!?! :rolleyes:
PTSideshow
01-11-2009, 10:41 AM
BLING!!!! :cool: ???
harbor fright stores have the aluminum solder rod, and most Home Despots have it read and follow all instructions. it work fine for most light duty applications.
:D
Smokedaddy
01-11-2009, 12:30 PM
You can give this a shot ...
http://www.pbase.com/smokedaddy/image/101061362
http://www.pbase.com/smokedaddy/image/101061361
-SD:
john917v
01-12-2009, 10:16 AM
I want to cool it, since the motor has a duty cycle. And, since it would be cool :o
