This may be kind of OT, however it could also cross over to be useful in the machine world. I have one of those small hand held vacuum pumps for removing fluids from things, like power steering fluid, coolant in automobile type applications for the most part. I want to build one with a electric motor, some different size fitting/hose fittings, and it will be used a lot if it turns out that it works for changing oil, coolant, etc as a maintenance item. I have no idea where to start, what type of motor would I need for this, HP, also type of pump as it will need to be self priming I'm sure. I have a Little Giant magnetic drive ($800 job), however it is not self priming, and is way to big for this application.
I also know they sell them however I need a project, and would like to scrounge this one if I can. I have a Lathe, no mill, I'm thinking of making the adapter/fittings myself for different pipe/hose sizes, I will need to put together the motor, and pump from purchased or scrounged items. I'm thinking ebay, surplus etc, but need some helpful suggestions on what to start looking for.
Clint
Clint
