View Full Version : Milling Machine on Lathe
Bones
01-24-2009, 07:56 PM
Was following the thread re:milling on the lathe, which referred back to some pics. of a milling machine mounted on the x-slide to do some simple milling.
My question: what results would on get by milling on a turning shaft with carriage feed engaged? Is this something that is done, or has been tried?
It seems an interesting possibility to me, it wouldnt do anything a regular cutting too wouldnt do, but am curious as to what sort of finish one would get, as well as speed of removing metal.
bones
S_J_H
01-24-2009, 09:44 PM
Typically excellent results if everything is setup properly.
Sometimes called "live tooling". Could use a small milling head or grinding head(tool post grinder), depends if the spindle can be locked into position how versatile it will be.
Can possibly be used for milling , thread milling, grinding etc.
Teenage_Machinist
01-24-2009, 09:58 PM
One might use a Taig headstock.
Bones
01-24-2009, 10:07 PM
tnks for the reply, will have to see if can find out any info on the subject, now that I know what its called.
bones
Spin Doctor
01-24-2009, 11:54 PM
bones
On most lathes wouldn't the spindle have to be running for the carraige feed to work? Even a Hardinge HLV has an electrical interlock to prevent feeding with the spindle motor off. This is one instance where mounting a Servo type mill feed on the carraige makes a lot of sense. With indexing plates you could do spline and gear work along with long keyways
NickH
01-25-2009, 01:17 PM
You get a very nice finish if you use a carbide milling cutter to machine a turning shaft, tolerance for interrupted cuts is very good too, I cleaned up the shaft on a single phase 3hp motor where some git had stick welded a coupling on the end, came out smooth as silk.
My original motivation for picking up a small milling head for my cross slide was to allow machining of helical grooves, splines, keyways and small gears before I got my mill & mill drill. It's still the easiest way I have for helical milling,
Regards,
Nick
John Stevenson
01-25-2009, 01:22 PM
The Sieg C4 can carry a rear mounted milling head and has a clutch that disconnects the spindle drive but still runs the leadscrew and cross slide screw by it's variable speed motor.
aboard_epsilon
01-25-2009, 01:50 PM
I've got one of these
http://www.lathes.co.uk/amolco/
its suposed to adapt to a myford and boxford ..
so that means southbend as well ..
although ive yet to see a pic of a boxford with one on ...
so can really work out how it will go on a south bend .
all the best.markj
NickH
01-25-2009, 02:16 PM
all the best.markj
Lucky beggar,
I chased loads of those but they all went for too much, I think the Myford fit is the reason, (I hope that second hand myford prices hold up 'till I can flog mine & get an Emco VP 10 or 11),
Nick
