View Full Version : puzzle ..what's wrong?
aboard_epsilon
01-25-2009, 08:43 AM
It's a British two pound coin .......can any of you spot whats wrong
http://img.photobucket.com/albums/v190/aboard_epsilon/2pound.jpg
ALL THE BEST.MARKJ
John Stevenson
01-25-2009, 08:51 AM
It's only worth a pound ?
[edit]
Just looked at three, all different dates obviously, but all look the same.
Peter.
01-25-2009, 08:57 AM
If you try to drive the geartrain from any one gear the last gear in the train will try to turn the driving gear opposite the way it's driving.
shadoof
01-25-2009, 09:02 AM
Cogs are locked, can't turn.
Edit, beat me to it!
aboard_epsilon
01-25-2009, 09:03 AM
I should have said Americans only ..,then thread may have lasted a long time
yes peter ....odd number of gears ..
explains ....why GB is going to pot.....when they cant even get things like this right .
all the best,,.........mark
01-25-2009, 09:17 AM
Heat it up and then freeze it and see if the centre pops out. Seeing that you stole the idea from Canada's two dollar coin I thought you should know about this. The question is is each part worth half the original?
John Stevenson
01-25-2009, 09:20 AM
No the outside bit is worth more because there is more surface area :rolleyes:
You can't press the new ones out as they have a lip in the inner bit, Early ones you could and some even fell out hence the design change.
Peter.
01-25-2009, 09:22 AM
You might be on to something there Evan. Make the center-part removable and you would be easy to give 1 in change for a 1 item.
Allan Waterfall
01-25-2009, 09:28 AM
What's wrong with it is that it's not in MY pocket,please post it to me tomorrow.:D
Allan
Lew Hartswick
01-25-2009, 10:15 AM
If those little circles are supposte to be gears, they had better find a
different artiste' to do the design. GACK!
...lew...
01-25-2009, 10:17 AM
Brilliant,do away with paper money and coins and just use nuts and bolts for currency-I'd be rich:D
A.K. Boomer
01-25-2009, 11:36 AM
Dont be beating on him about that, the Canadians ripped off the idea from the Italiano's...
01-25-2009, 12:48 PM
What? The part about it falling apart?
QSIMDO
01-25-2009, 01:00 PM
Is that coin where they got the idea for crop circles?
A.K. Boomer
01-25-2009, 03:14 PM
No - I was talking about this comment,,,,,"Seeing that you stole the idea from Canada's two dollar coin I thought you should know about this."
I of course wanted to use my own smart ass comment and did, I really dont know where the multi-composite coin was developed but I think there's a good chance it wasnt Canada
John Stevenson
01-25-2009, 03:18 PM
actually it was pre- roman times.
they had a bronze outer and the centre was made out of a hole .........................
old-biker-uk
01-25-2009, 03:44 PM
Shrinking Pound, Dollar, Euro - you name it, this guy (http://teslamania.delete.org/photos/ShrunkenCoins1.PDF) will shrink it for real.
Mark
Greg Parent
01-25-2009, 04:00 PM
Are they gears or Celtic symbols?
aboard_epsilon
01-25-2009, 04:12 PM
here's a clearer pic...the one I posted was a scan of a well worn one or they took the teeth off later ones cause they realised they goofed. . ..you can see the teeth on these .
http://www.lhup.edu/~dsimanek/coin.gif
Alistair Hosie
01-25-2009, 04:25 PM
Mark my dear friend have you got too much time on your hands:D:DAlistair
